Author Topic: Water in my front fogs - Mk6 GTI  (Read 2775 times)
Offline dje
« on: 23 February 2015, 18:02 »
Hi
It's about 1.5cm deep!
Does anyone else have an issue with this?
Is there an easy fix or am I looking at two new units?
Thanks
Offline Buck
  • Das Auto
Re: Water in my front fogs - Mk6 GTI
« Reply #1 on: 23 February 2015, 22:43 »
I had this after floods a couple of years ago.
If you remember be the plastic cover in the wheel arch then remove the bulb unit you can then (with some difficulty) get a tube in to suck the water out or get a cloth in to soak up the water.
Official removal of the fog light units requires the bumper off!
Offline danpen1306
« Reply #2 on: 24 February 2015, 09:20 »
I recently had this issue although not quite as bad as yours. Luckily my GTD was still under warranty so VW replaced them no questions asked.
New - 2019 Golf R, Indium Grey, 5 door, Black gloss Pret's, Dynaudio
Gone - 2018 Audi S3 Saloon, Ara Blue, 19" V spokes, Tech pack
Gone - 2016 GTI PP, Black, 5 door, DSG, CarPlay
Gone - 2012 GTD, Candy White, 5 door, Charleston's, DSG, Leather, RNS-510, Bluetooth, Parking Sensors and a Big Smile
Offline dubber36
« Reply #3 on: 24 February 2015, 16:22 »
I'd remove them and dry them out fully in the airing cupboard for a couple of days.
The slightest bit of moisture left in them will cause them to mist up.
Offline dje
« Reply #4 on: 25 February 2015, 10:41 »
Thanks everyone, I'll locate the cover in the wheel arch, drain and get myself a replacement cover as it clearly wasn't up to the recent floods
Offline Buck
  • Das Auto
« Reply #5 on: 25 February 2015, 19:47 »
As dubber says, make sure they are dry inside
VW advised me to drive with the fogs on for a few journeys to generate some warmth in there.
I'd also suggest a warm hair dryer on the lens to warm it up but be prepared to be patient - it takes ages!!
Offline candywhite12
« Reply #6 on: 25 February 2015, 20:08 »
i had (have) the same issue, floods 2 months ago  :sick: i kind of let the water take care of itself as i wasn't sure how to access the case, which was a huge mistake as it has now evaporated but left a brownish hue at the base of both my fogs. Removing the bulb only leaves a tiny opening so don't know whether one could actually use a hose or a cloth there
Current: GTI 8.5, Moonstone Gray, 5dr, Black Estorils 19''. pan, DCC
Wife's: mk8 TSI 1.5 RL, 5dr atlantic blue, DSG, Norfolk 17", pan s/r, leds
Son's: mk7.5 TSI 1.4 RL, 5dr tornado red, DSG, Singapore 17", pan s/r, leds
Before: mk6 GTI 5dr candy white, DSG, Monza Shadow 18", s/r, bi-Xenons, DCC
Even before that: mk5 GT 5dr tornado red, manual, s/r
Offline mike.
« Reply #7 on: 25 February 2015, 22:25 »
Same thing happened to me, I just used a small bit of clear pipe attached to a wet and dry vacuum cleaner hose and sucked it out.
Then I left them open overnight in the garage and no problems since.
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Keithuk
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline Mattyj
« Reply #9 on: 01 March 2015, 13:25 »
As a foot note, they are easily dislodged if you hit a deep puddle i drilled the tops of mine and cable tied them in was fed up of buying new ones!
