Author Topic: AUM injectors  (Read 5065 times)
Offline Screech16v
  • MK3 20vt AGU
AUM injectors
« on: 20 February 2015, 22:21 »
I just read that aum injectors are larger than agu,is this true?
Offline rockmonkey69
Re: AUM injectors
« Reply #1 on: 21 February 2015, 01:11 »
Yes
AGU 150 205cc
AUM 150 314cc
(@3 bar)
Offline Screech16v
  • MK3 20vt AGU
Re: AUM injectors
« Reply #2 on: 21 February 2015, 15:26 »
Ah good stuff!,so next question,is it worth fitting aum injectors to my agu just before a stage 2 remap or will my agu  injectors be enough,whats the first thing to max out,i have ko3s ,front mount,tip,forge actuator etc
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: AUM injectors
« Reply #3 on: 21 February 2015, 15:43 »
you can't put AUM injectors in an AGU. For stage 2 you can go up to around 220bhp without the need for bigger injectors
Offline Screech16v
  • MK3 20vt AGU
Re: AUM injectors
« Reply #4 on: 21 February 2015, 15:51 »
God dam it I thought they were interchangeable ,ok thanks for the bad news wazzer :grin:,will the agu injectors be at 100% at 220 then or is it the ko3s that gets weezy
Re: AUM injectors
« Reply #5 on: 21 February 2015, 21:45 »
Wazzers correct there, they're not interchangeable. It's recommended to upgrade the AGU injectors when people fit k03s or larger
Offline Screech16v
  • MK3 20vt AGU
Re: AUM injectors
« Reply #6 on: 21 February 2015, 23:17 »
Had ko3s on for around 8 months with agu injectors and a map for ko3,works well enough but its time to get it all mapped properly for the hardware that's on my car,its just some aum injectors were going begging that's why I asked the question,some are saying I can use aum injectors if I fit the bigger injector seats which simply unscrew ,so I still have that option to explore,thanks for your input so far  :smiley:
Re: AUM injectors
« Reply #7 on: 21 February 2015, 23:27 »
The injectors will be fine while it's running what it was mapped for, it's when you have your k03s mapped them agu injectors will likely struggle. If you want to use aum/auq injectors, it's worth noting the aum/auq injectors are shorter than the AGU injectors.
Offline ap_gt3
Re: AUM injectors
« Reply #8 on: 22 February 2015, 08:47 »
My standard injectors were maxed just before 230bhp
Golf mk4 AUM... fmic, custom exhaust, 3" dp/decat, bbt actuator, s3 injectors, LCR fuel pump, sfs supersize tip, jetex filter, g60/vr6 clutch, badger 5 remap : 232.5 bhp / 242.3 lbft
Offline Screech16v
  • MK3 20vt AGU
Re: AUM injectors
« Reply #9 on: 22 February 2015, 10:36 »
Right so from peoples experience what's the injector of choice for a mapped ko3s as this is the first thing to max out
