Author Topic: AUM injectors  (Read 5074 times)
Offline rockmonkey69
Re: AUM injectors
« Reply #10 on: 22 February 2015, 10:44 »
It's best to consult with your tuner what he prefers as they're the one mapping it. They may already have a file ready for an AGU on a particular set of injectors in which case it would save them some time. (Being an old car it's likely they will have files for just about every imaginable setup, but check with them first)
Flow of popular injector upgrades for AGU can be found in this thread:
http://www.golfgtiforum.co.uk/index.php?topic=209124.0
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: AUM injectors
« Reply #11 on: 22 February 2015, 11:37 »
I run the Calibra yellows in mine. K03s should run fine with them, move up to a K03 hybrid/K04 and you'll more than likely need Saab reds.
Be mindful of the part numbers when you look for any injectors though and always get them checked over for flow/spray pattern before you fit them
Offline Screech16v
  • MK3 20vt AGU
Re: AUM injectors
« Reply #12 on: 22 February 2015, 13:20 »
Thankyou  guys  :cool:
