Author Topic: ecu  (Read 2799 times)
Offline viperjsy
ecu
« on: 15 February 2015, 22:46 »
hi I just purchest a golf gti t ecu from ebay it is the same as mine the seller says it is remaped to stage 1 from 150-190bhp on my ecu when car is on boost it boosts to 0.5 bar how would I tell if it has been remaped will it boost more
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
Re: ecu
« Reply #1 on: 16 February 2015, 10:16 »
0.5bar is standard boost. After mine was mapped I'm getting around 1 bar. Could be a duff ecu or you have a boost leak somewhere?
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline viperjsy
Re: ecu
« Reply #2 on: 17 February 2015, 00:05 »
i have not got the stage 1 ecu yet the 1 that is in the car is standard 1 cant wait to see how the car gose with the new ecu
I will updait when I get it  would I need to change the spring is the dv for stage 1
« Last Edit: 17 February 2015, 00:09 by viperjsy »
Offline viperjsy
Re: ecu
« Reply #3 on: 18 February 2015, 22:14 »
hi just an updait the ecu turned up today and I put it in new it go's like hell
it boosts to just over 1 bar
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: ecu
« Reply #4 on: 19 February 2015, 18:12 »
goes like hell up to 40mph you mean :wink:
Offline benmanc
Re: ecu
« Reply #5 on: 20 February 2015, 06:20 »
Gose go's... *Goes.  :whistle:
Offline viperjsy
Re: ecu
« Reply #6 on: 20 February 2015, 12:19 »
yeah and it pulls well in all gears better then standard
