Author Topic: mk2 1.3 golf  (Read 3721 times)
Offline Josh g
mk2 1.3 golf
« on: 11 February 2015, 21:44 »
 I have got a mk2 1.3 golf and the fan doesn't come on when it's up to temperature I know the fan works because I linked it straight to the battery have read up on it can't seem to find a straight answer for  it but by the sounds of it its the coolant temp sensor but I don't get how it could be that if it reads it's up to temperature or is there a thermal switch for the cooling fan if so where would I find it ?
VW BUSH
Re: mk2 1.3 golf
« Reply #1 on: 11 February 2015, 22:04 »
Its a switch normally on the rad near the fan on the bigger engines :smiley:
Offline Josh g
Re: mk2 1.3 golf
« Reply #2 on: 12 February 2015, 15:45 »
Is that the one half way down the rad with on the battery/passenger side?
Offline Josh g
Re: mk2 1.3 golf
« Reply #3 on: 12 February 2015, 18:48 »
Swapped it with the one off my 1.6 driver that know works but the fan still doesn't come on any ideas?
VW BUSH
Re: mk2 1.3 golf
« Reply #4 on: 12 February 2015, 19:45 »
Start checking the wires and plugs back from the fan and switch.
Helps if you have a meter
Offline Josh g
Re: mk2 1.3 golf
« Reply #5 on: 12 February 2015, 19:54 »
Okay thanks will try that when I next get chance
Offline Santiago
Re: mk2 1.3 golf
« Reply #6 on: 14 February 2015, 22:01 »
The fan shouldn't come on until the engine is well above normal operating temperature. Are you sure it's getting hot enough that the fan should be operating? Somewhere between 2/3 and 3/4 on the gauge?
Offline Waspy
Re: mk2 1.3 golf
« Reply #7 on: 14 February 2015, 22:46 »
Mine tends to come on a little past half way. Still, it rarely comes on, only when I have been sat in heavy traffic.
Offline Sgt_Lemon
  • 8v owners club
Re: mk2 1.3 golf
« Reply #8 on: 15 February 2015, 14:03 »
Take the plug of the rad temp sender and bridge the connectors. If it comes on then it's the sensor, if it doesn't then it's the wiring somewhere.
Offline Josh g
Re: mk2 1.3 golf
« Reply #9 on: 17 February 2015, 22:46 »
Thanks for the help not had chance to have a look at it yet been to busy with work should be able to get a chance to have a look tomorrow. I have let it get to 3/4 on the temperature gauge before and nothing happened.
