Author Topic: Pioneer Headunit wiring  (Read 4083 times)
Offline LeeOxley
« on: 29 January 2015, 11:33 »
Anyone had any experience wiring in a Pioneer DEH series head unit? I have an iso adapater but it is from Corsa so pretty much useless without rewiring. Im a wirey person so if anyone knows what wires go where that would be a great start ;)
Offline dubber36
Re: Pioneer Headunit wiring
« Reply #1 on: 29 January 2015, 12:26 »
Does your car have ISO plugs?
Offline LeeOxley
« Reply #2 on: 09 February 2015, 16:19 »
It does indeed
Offline dubber36
« Reply #3 on: 09 February 2015, 17:42 »
If you have a Pioneer to ISO adaptor, I can't see why it won't work. You'll need to make sure both the red and yellow +ve's are permanent lives, but other than that, ISO is ISO.
Is there fuse in the radio itself?
Offline LeeOxley
« Reply #4 on: 10 February 2015, 14:36 »
I know the radio works as it literally came out of my corsa working, tried it in my golf, nothing and put it back in my corsa, fine. I have a corsa iso to pioneer adapter but the pins are obviously differently set up. The iso from the car doesnt have a permanent live so I cant turn the pioneer unit on. Apparently there is a perm live somewhere close but im not a wirey person so not really my forte.
Offline dubber36
« Reply #5 on: 10 February 2015, 14:59 »
Hang on, are you saying that the cars factory ISO plug doesn't have a permanent live? What radio was in the Golf to  begin with? Did that work? Have you checked the fuse?
Put "ISO radio pinout" into Google Images and you'll see what wires should be where.
Offline LeeOxley
« Reply #6 on: 15 February 2015, 02:03 »
Im not sure what radio model it was but it needed pins to take it ou8t of the dash. It wasnt just a handle that pulled it out. I dont know if it is actually called an iso cable.(the one from the car). The black and brown spluit blocks which all the cables in. The radio could be turned on with no key by turning the volume switch on, meaning it had a permanent live not an ignition live. (I think i may have said it backwards in the last post)
Offline dubber36
« Reply #7 on: 15 February 2015, 09:39 »
Only the very last Mk2's had an accessory position on the key for the radio. Nearly all cars radios were permanent live.
Offline itavaltalainen
« Reply #8 on: 15 February 2015, 10:47 »
The Pioneer will expect standard ISO connectors, VW never sticks to the standard pin out thou....
I put a wiring diagram together for the mk3, that includes the standard ISO pin out, easy to sort out if you have a multimeter. You don't need to cut any wires to correct it, just unhook pins and put in in correct order.
wiring diagram:
http://www.motor-talk.de/forum/aktion/Attachment.html?attachmentId=713417
Offline LeeOxley
« Reply #9 on: 16 February 2015, 14:39 »
Is there anywhere that sells a harness/adapter from vw to pioneer unit? I havent got a multimeter to test wires.
