Author Topic: Window open fault  (Read 2599 times)
Offline remlapeel
Window open fault
« on: 27 January 2015, 17:37 »
Just to add another fault to the long list of crap I have had with my car.
Today I went to open my drivers window to get a ticket for a car park and noticed the one touch open didn't work. Thinking the problem would fix itself once I restart the engine, I left it and went to work. On my way out I opened the window to pay and again it didn't work. I have to press and hold for both up and down.
Is this just another fault with my piece of crap, or is this something I have done without realising ?
2015 MK7 Golf R 3 door, DSG, lapiz blue, 19" wheels, winter pack, keyless entry, dynaudio and high beam assist.
Offline phazer
Re: Window open fault
« Reply #1 on: 27 January 2015, 17:55 »
By the sounds of it, the one touch just needs "re-programming", it'll be in the handbook but every car I've had was the same - wind window down and then wind it up and hold the switch once the window is closed for ~30 seconds. Job done.
Offline DougL
« Reply #2 on: 27 January 2015, 17:57 »
Try a reset. Open the window slightly. Ignition must be on obviously. Close it again. Then pull up on the switch and hold it there for three seconds. These instructions should be in the manual.
Tornado Red GTI 3dr manual
Previous Golfs Mk1 GLS and GL, Mk2 GL and Driver, Mk3 GL, Mk4 GT TDI, Mk6 TDI (and a Mk2 Scirocco 20 years ago)
Offline fredgroves
« Reply #3 on: 27 January 2015, 18:01 »
Mine does this randomnly from time to time.
I've never "reprogrammed it", it just comes back at some point later. Switching the car off, locking it, leaving it 5 mins (the usual reboot for broken crap) seems to make no difference.
I'm sure the diagnostics has an error log, but I don't have VCDS to look and have never taken it to a dealer about it as it is just random.
Offline GeoBog
« Reply #4 on: 27 January 2015, 19:07 »
In my old Renault, this would only happen when I'd disconnect the battery leads. To "re-program" the windows again I had to lift and hold for 3 sec all window control buttons on the driver's door and that's it. I don't see why on the GTI would be different. It is not normal for the window module to lose it's settings without reason. I would book it in for a check.
« Last Edit: 27 January 2015, 20:25 by GeoBog »
2020 VW T-Cross SEL
2020 Renault Megane RS Trophy 300
2012 Fiat 500 Twinair
2007 Renault Megane 2
The two most important days in your life are the day you are born and the day you find out why.
Offline topher
  • Administrator
  • fully functioning
« Reply #5 on: 27 January 2015, 19:47 »
As said lower the window a touch then pull the up switch all the way until the window hits the top, then release the button and hold it all the way up again for a few seconds (you usually hear a quiet little click from the window motor when it works properly)
The door module can lose it's learned stop position for a few different reasons. I've not seen it myself on a Mk7 yet but on earlier cars it can be a sign of the door wiring harness starting to break up in the rubber boot that protects the wiring between the A-pillar and the door.
