Author Topic: LED rears won't physically fit my car!  (Read 8587 times)
Offline Snoopy
  • Moderator
  • Geoff.
Re: LED rears won't physically fit my car!
« Reply #10 on: 12 January 2015, 18:31 »
Never seen them on one before.
Mines a Feb 2010 build and does not have them.
Im not even sure how the ordinary lights fitted with them there.
Current Garage:
35+ years of GTI ownership.
Offline mwad gti
« Reply #11 on: 12 January 2015, 20:06 »
So do all 59 Plate GTi's have this? Or is this a one off?
This was the next mod I was going to do, but looks like I may have to cut bits off my car!!
I'd think twice  :shocked:
Does seem weird.....
2019 3 door manual GTi Performance in black
Bought 2 years ago as a 1 owner car, FVWSH and 10k miles
It’s a keeper
Offline vertex
« Reply #12 on: 12 January 2015, 22:31 »
Not sure, this is the first xenonz uk has seen.
I'm taking an angle grinder to it on the weekend. I'll let you know how it goes.
Offline vertex
« Reply #13 on: 12 January 2015, 22:34 »
I'll post comparable pics of the rear housing for the lights. With the standard lights there's plenty of space for that fin, however the LEDs have more at the back.
Offline Adycakes
« Reply #14 on: 13 January 2015, 13:14 »
Cool, thanks for that.
How easy is it to get the lights out, might take a look this weekend before purchasing the lights.
Offline dubber36
« Reply #15 on: 13 January 2015, 14:34 »
Easy peasy. Pull the carpet trim away in the boot and you'll see a plastic wing nut. Just undo that, slide the lamp out and unplug the connector. To get to the fixings on the inner lights, just pop the cover off the tailgate trim panel to expose them.
Offline Adycakes
« Reply #16 on: 13 January 2015, 17:45 »
Thanks! I would take a look tonight but it's peeing it down here!
Offline SRGTD
« Reply #17 on: 13 January 2015, 19:12 »
Vertex, do you have the same fin or bracket in the area behind the right hand rear light unit? If not, and if no one else has this, is it possible that your car may have had a repair to the left had rear corner, and a replacement aftermarket, non-VW panel used for the repair? Is there a difference in the quality of the paint in this hidden area on the left hand side compared to the area behind the right hand light cluster, which might be a tell tale sign of a repair?
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline andygo
« Reply #18 on: 13 January 2015, 20:49 »
The extra metal is because your car is white. The white cars were made as prototypes and have all sorts of useless extra bits of metal added here and there. The extra weight is just one of the reasons white GTi's are slow...
Offline vertex
« Reply #19 on: 13 January 2015, 21:52 »
The car definitely hasn't been in a crash to that extent, (I'm very particular and can spot a repair very easily). The paint is same inside and out. (He says nervously hoping it wasn't in a crash. VW aren't allowed to sell cars like that are they?!)
Not sure on the other side as I started on the left so ended it soon as I saw the fin.
« Last Edit: 13 January 2015, 21:55 by vertex »
