Author Topic: REAR TYRES BALD IN 5000 MILES  (Read 4483 times)
sus
« on: 07 January 2015, 13:09 »
hi bought my GTD end of july 2014 it was secondhand with only 15k miles on it, i don't drive it much its mainly the mrs, she went to look at a horse (150 mile round trip) on saturday, when she got back said the car felt funny, i checked tyre pressure (the light hadn't come on) pressures were fine so i looked thinking maybe a bulge, the garage i bought car from had insisted fitting 4 new tyres before i took delivery, anyway the fronts are still like new but the backs are both bald from insides over 1/2 way across,i took car back to garage, asked if they had just put fronts on but no they had put 4 on and even showed me receipt,anyway they took car and put 2 new tyres on and had a 4 wheel alignment done which they say the camber was way out,
should i be worried or would camber bald tyres in 5000miles the car has dcc
Offline Organisys
  • Old and Slow...
Re: REAR TYRES BALD IN 5000 MILES
« Reply #1 on: 07 January 2015, 13:22 »
If the alignment was out this could have chewed up the tyres. You only need to be concerned if they continue to wear at the same rate as they did previously.
If they do still wear fast, get the rear suspension bushes checked and also maybe the wheel bearings, although you would most likely hear the problem from these before you got any bad tyre wear.
 :smiley:
« Last Edit: 07 January 2015, 13:23 by Organisys »
sus
« Reply #2 on: 07 January 2015, 13:27 »
thanks, should i get vw to check the car as its still got warranty till march ?
Offline Organisys
  • Old and Slow...
« Reply #3 on: 07 January 2015, 13:31 »
Ask them if they check the bushes. If they didn't then no harm in asking them too.
Offline dubber36
« Reply #4 on: 07 January 2015, 16:37 »
Going by the picture in the other thread, you car has non factory spec wheels on it. Many on here have later found out that their cars have cheap replica wheels on them, probably due to the originals being damaged beyond economical repair. Yours appear to be VW accessory wheels, so no issues on that front, but is may point towards previous wheel-kerb interfacing which may well have bent something out of shape.
The tolerances are quite fine, so even the slightest amount of discrepancy in suspension geometry will cause uneven or accelerated tyre wear, so I would suggest that yours needs to be checked again by someone with the right equipment that knows how to use it.
sus
« Reply #5 on: 07 January 2015, 18:41 »
it has just had 2 new tyres and a 4 wheel alignment they said the camber was way out
sus
« Reply #6 on: 07 January 2015, 18:43 »
is it possible the alloys were spec'd from new, i spec'd ACS wheels on a new bmw before
Offline charlie
« Reply #7 on: 07 January 2015, 18:50 »
If the wheels you show in your pic I've just checked out they aren't standard look a bit like audi wheels to me but they look good all the same. If you take one of you should find a manufacturers mark  :smiley:
2012 black pearl Golf gti mark 6 5 door leather cruise 510rns bluetooth acc dab sunroof park assist rear camera parking sensors storage pack and the luxury pack :-) sold :/( now aiming a 2013 passat alltrack
Offline Booth11
« Reply #8 on: 07 January 2015, 19:18 »
Well hopefully that may have resolved the issue, so just keep a close check on future tyre wear with regular inspection etc.  if the problem persists then either get another 4 wheel geometry check done or start looking at other potential causes, as suggested.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline seabrook132
« Reply #9 on: 07 January 2015, 20:00 »
They are khartoum wheels, an official VW accessory
http://www.volkswagen.co.uk/owners/accessories/all/all/all/Khartoum%2018
2011 GTI DSG 5dr, Tornado Red, 18" Monza Shadows, Heated Leather, RNS-510, MDI, Bilstein B16 PSS10 Coilovers, Ohlins DCC Cancellation Kit, Audi TT-RS Front Top Mounts, Whiteline 24mm Rear ARB, Michelin Pilot Sport 4, 034 Motorsports Street Density Engine and Gearbox Mounts, Audi R8 Red Coil Packs, NGK BKR7EIX, Millers 5W-40 Nanodrive
