Author Topic: Morning Mis-Fire - is boggling me  (Read 2373 times)
Offline smithy7861
« on: 06 January 2015, 15:34 »
The last two mornings the Golf has started up fine and ticking over perfectly, I start my journey and with-in a couple of minutes the engine management lights starts to flash and the car is mis firing, after about 15 -30 seconds of this, the car then drives perfectly normal/ no mis firing/ no power loss/ nothing perfectly normal for the rest of the day....what the hell is going on??? ive had the car for 1.5 years and the one thing i haven't done yet is change the spark plugs, could this be the problem or just a glitch passing through due to cold weather etc ....any thoughts guys?
Thanks
Smithy
Offline viperjsy
Re: Morning Mis-Fire - is boggling me
« Reply #1 on: 06 January 2015, 15:51 »
change the pulgs and see
Offline ap_gt3
« Reply #2 on: 06 January 2015, 16:59 »
Id plug her in and check for codes
Golf mk4 AUM... fmic, custom exhaust, 3" dp/decat, bbt actuator, s3 injectors, LCR fuel pump, sfs supersize tip, jetex filter, g60/vr6 clutch, badger 5 remap : 232.5 bhp / 242.3 lbft
Offline oVerboost
« Reply #3 on: 06 January 2015, 19:49 »
Coil pack starting to break down? As has been said, without plugging it in, it's pointless playing the guessing game tbh.
Offline smithy7861
« Reply #4 on: 06 January 2015, 22:56 »
Ill check for codes in the morning
Offline smithy7861
« Reply #5 on: 07 January 2015, 15:45 »
Right got the codes:
16684 – Random/Multiple Cylinder Misfire Detected
16687 - Cylinder 3 Misfire Detected
am I right in thinking that a spark plugs change would be a good idea and quiet possibly be the cause?
thanks Guys
Offline rio_gti
« Reply #6 on: 07 January 2015, 16:05 »
yeah try that first, then if the code comes back swap the coil pack 3 with 1 and see if the misfire moves cylinder, if it does it is the pack on its way out... check your local vw garage for any recalls on your car
Offline smithy7861
« Reply #7 on: 07 January 2015, 16:18 »
Cheers Rio and all to have replied :)
