Golf mk5
Edition 30 DSG Issue
Topic: Edition 30 DSG Issue (Read 3077 times)
davym2222
Just got here
30 December 2014, 15:02 »
Hi there,
i have a Golf GTI Ed30 with the 6 speed DSG gearbox and has been running fine for the last four years. Over the last month or so the gearbox seems to kickdown randomly when driving along.
this usually happens after you are up to speed and in 6th gear. you are travelling at a constant speed and it will change down on its own to 5th or sometimes to 4th gear. If you stop this seems to reset on its own then it will at a random point do the same.
the funny thing is there are no errors from the VAG com and the box works as normal in manual mode.
this only seems to be an issue in Auto only
the box had the oil and filter changed at 40k miles in 2012 and now has 52k miles on the clock.
does anyone have ant idea what this issue might be before i hit the dealer
Thanks for your help in advance
David.
th3_f15t
Re: Edition 30 DSG Issue
01 January 2015, 11:09 »
I would of suggested a faulty throttle position sensor perhaps although the lack of error codes is strange. Check all the wiring to the throttle both in the cabin and in the engine bay (if you can find it!) and check electrical connections everywhere.
This sounds like an electrical problem, not mechanical as it sounds like the car thinks you're going for kick down (if that's the right term for it). I'm a manual car driver so little hands on with DSG but hope it's a start!
Good luck.
Moving over to Flickr, sorry for the broken picture links!
davym2222
Just got here
05 January 2015, 11:44 »
ok thanks ill have a hunt about and see what i can find :-)
th3_f15t
05 January 2015, 12:12 »
Also, if you have VCDS (or access to it), do a DSG box reset. Read the other day about how it "learns" your driving style and the profile it's created may be screwed so cleaning it out may help (and it's only the cost of a VCDS scan).
davym2222
Just got here
14 January 2015, 12:22 »
rear ABS pickups cause the issue with the random shifts in gear
just incase anyone else has a similar issue this might be a place to look
Thanks.
th3_f15t
14 January 2015, 18:04 »
Well that's certainly very handy info to know, cheers for updating us with a result. All fixed now I assume?
davym2222
Just got here
Reply #6 on:
28 January 2015, 14:14 »
sure is after a week or so of test drives the issue is gone :-)
th3_f15t
Reply #7 on:
28 January 2015, 17:15 »
Then go forth and enjoy your DSG equipped car, you lucky son of a gun.
Golf mk5
