Author Topic: ABS light on dash  (Read 3305 times)
Offline james2
  • No scammers please.
ABS light on dash
« on: 26 December 2014, 20:33 »
What will it be causing it ? Sensors.  :sad:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: ABS light on dash
« Reply #1 on: 26 December 2014, 20:43 »
Usually a speed sensor, you'll need a VAG COM scan to tell you which one though. Once a new one is fitted it should turn off in a few miles as it self tests
Offline gm8
« Reply #2 on: 27 December 2014, 11:51 »
have a look at the front wheels, Ill had a CV gaiter go in the past and cover the sensor in crap. Clean with contact cleaner and light went off.
Offline james2
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 31 December 2014, 03:23 »
yep they'll fit. I'd only change the dead one though, they can be a hassle to get in/out
Offline itavaltalainen
« Reply #5 on: 31 December 2014, 16:49 »
which one's dead?
is it a sensor, what did vcds say?
Offline james2
« Reply #6 on: 31 December 2014, 21:25 »
which one's dead?
There was a fault code, i tryed deleting it but i could not. Ill scan it tomorrow. One of the back wheels gets red hot because the break is seized , its could be that sensor. I would fix it but it comes and goes, its not getting hot anymore.  :embarrassed:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 01 January 2015, 00:27 »
Common fault for the rears to seize, it's the handbrake mechanism. You can fit the Sharan springs to help it release better
Offline james2
« Reply #8 on: 03 January 2015, 16:17 »
Thanks for the tip.
Fault code is 00283 front left speed sensor. Is that the passanger side ?
Offline gm8
« Reply #9 on: 03 January 2015, 18:37 »
yeah
