Author Topic: not got much go  (Read 4716 times)
Offline yougy
not got much go
« on: 23 November 2014, 14:05 »
hello, iv a 1999 golf mk3.5 20l egg engine convertible 87000 on clock, it starts ok it seems like a bit of a miss on tick over, when driving it seems a little slow on power is this right or any ideas wot could be wrong, its had new leads,plugs, cap n arm
thanks dave
thats fooked it
Offline itavaltalainen
Re: not got much go
« Reply #1 on: 23 November 2014, 15:18 »
Duff coil would be first idea.
Any fault codes in ECU?
Offline yougy
Re: not got much go
« Reply #2 on: 23 November 2014, 15:35 »
I checked about 2 months ago and it was all clear
dave
thats fooked it
Offline tweed
Re: not got much go
« Reply #3 on: 24 November 2014, 21:37 »
Fuel pump relay
Offline yougy
Re: not got much go
« Reply #4 on: 03 December 2014, 18:47 »
right unplugged maf ran so much better, picked 1 up fitted it today, now engine wants to stall when I slow down wots going on. lost me vag coder
thanks dave
thats fooked it
VW BUSH
Re: not got much go
« Reply #5 on: 03 December 2014, 18:59 »
thanks dave
Clean the throttle body
Offline yougy
Re: not got much go
« Reply #6 on: 03 December 2014, 19:01 »
its clean dude, didn't have this problem with old maf just bad tick over n not much power
thats fooked it
Offline clancy
Re: not got much go
« Reply #7 on: 07 December 2014, 23:23 »
Got access to a live data scanner ? Can see what's properly going on then, will cost about £40 to get someone to do it if not
MK3 GTI 16v
Offline GOLF-MK3-GTI
Re: not got much go
« Reply #8 on: 07 December 2014, 23:59 »
thanks dave
Disconnect battery for a few hours best overnight then reconnect both terminals. Then turn on the ignition, don't start the engine though and don't touch the pedals. Leave on for 30 seconds then turn ignition off and then start the car straight away not touching any pedals. That should align the throttle body.
Offline yougy
Re: not got much go
« Reply #9 on: 24 December 2014, 14:48 »
thanks dave
I will try that tonite dude n see wot happens, iv changed the plugs,dizi cap,rotor arm,coil,maf,relay 167,relay30,leads n fuel filter, if I remember right the throttle body was clean last time I looked but will check again.
any body around the bude area got the full diagnostic iv only half of it
thanks dave
« Last Edit: 24 December 2014, 15:44 by yougy »
thats fooked it
