Author Topic: front seat split  (Read 2182 times)
Offline nodwardo
front seat split
« on: 12 October 2014, 21:14 »
Hi guys.
Firstly i must apologise as still havent had time to set a photobucket account up for pics of my build progress.
Anyway, was wondering if anyone knew how to split the fron seat apart ie. The base away from the back. Ive bought a new recaro interior but need to swap a seat base as one is damaged.
Thanks in advance
Offline nodwardo
Re: front seat split
« Reply #1 on: 13 October 2014, 08:11 »
29 views and nobody knows.
Seriously though.
BUMP or the highest order
Offline SI74
« Reply #2 on: 13 October 2014, 09:43 »
With an attitude like that it could put people off helping you.
Have you look at the seat and tried to work it out yourself? Is it 3 door or 5 door.  A mk3 seat comes apart in about 2 minutes once you look it it's dead easy.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #3 on: 13 October 2014, 09:46 »
Yes it is possible as swapped the base foam on my drivers seat with a decent passenger side one I sourced cheaply.
It's quite simple really and the only fiddly bit Is unhooking the metal rods that hold the seat cover on. Everything else is a case of unscrewing and unclipping.
« Last Edit: 13 October 2014, 09:48 by thai-wronghorse »
Offline nodwardo
« Reply #4 on: 13 October 2014, 20:43 »
Thanks very much.im just waiting on my interior coming back to have a look at it. Think im going to put one of them heated seat kits in.has anyone had a go of one of them before? Look pretty easy to install.
thanks again lads
« Reply #5 on: 13 October 2014, 22:02 »
Once you've removed the lower plastic surround trim it becomes very clear how they come apart. The uppers are more difficult, especially if you have a lumbar adjustment knob as these are f**k*rs to remove without breaking out or tearing the covers.
Adding heated seat pads shouldn't be an issue at all once you've got the cover unhooked.  :smiley:
Offline nodwardo
« Reply #6 on: 13 October 2014, 22:19 »
Thanks very much mate ill have a bash as soon as i get them back.thanks again
