Author Topic: petrol filler switch  (Read 3206 times)
Offline Screech16v
  • MK3 20vt AGU
« on: 04 October 2014, 19:03 »
Had this golf over 4 yrs and only just noticed today a swtich inside the filler neck,it gets pressed when the cap goes on,theres a wire next to it on the outside of the neck that has corroded off,is this switch supposed to cut the engine/bring light on if the cap is removed while still running
Offline gasketface
Re: petrol filler switch
« Reply #1 on: 04 October 2014, 19:47 »
Everyone runs outside to see if they got one............. :grin:
Offline itavaltalainen
« Reply #2 on: 05 October 2014, 00:35 »
That "switch" is the nipple for the tank vent.... push it with you finger while filling and you can fill the expansion tank as well (i.e. squeeze more fuel in before a long journey).
I would think the wire that has corroded off is the grounding strip.
Offline snozan
« Reply #3 on: 05 October 2014, 09:06 »
I wouldn't recomend to fill it all the way up. When it cuts it's enough. Maybe in cold weather is isnt as dangerous as in varm weather, but as i said, when it cuts it cuts for a reason.
Golf MK3 GTI 16v Colour Concept - Bumble bee Edition '96
« Reply #4 on: 05 October 2014, 11:33 »
There's a lot of safety with petrol tanks; in cold weather and if you immediately fire it out the back (on long journey) it's not dangerous; fill it up with cold petrol in Turkey in the summer when it goes over 40 degrees air temp then it may go pop thou without the expansion tank.
Had about 70-75l total in my supposed 60l tank in my AAM estate :D
Offline Screech16v
  • MK3 20vt AGU
« Reply #5 on: 05 October 2014, 12:32 »
cheers guys,I never put more than half a tank in anyway,if I'm going on a long trip I will use something that's good on fuel lol
Offline Len
« Reply #6 on: 06 October 2014, 13:10 »
No expansion tank on mine! Just the tank and the filler neck!
www.sas.org.uk
www.the-ace.org.uk
« Reply #7 on: 06 October 2014, 13:18 »
Unless modified I doubt that ;)
