Poll
Where is the best place to take the Boost Gauge feed from?
Diverter Valve Vac Line
1 (50%)
Fuel pressre Reg Vac Line
1 (50%)
Total Members Voted: 2
Voting closed: 30 September 2014, 10:29
Author Topic: Where is the best place to take the Boost Gauge feed from?  (Read 2795 times)
Offline TETSUOXGEZ
  • "If in doubt, flat out"
So after scouring the net i found loads of conflicting information as to where to "T" in to take the feed for a Boost Gauge
I am personally running from the FPR, but i didnt know anything else at the time.
Running from the FPR is supposed to give a more acurate result, but you run the risk of an aire leak... and less air to the FPR means running lean... major no no on a turbo. :cry:
Running from the DV line is supposed to give a less accurate result  :undecided:but you then dont run the risk of running lean
What are your opinions and does anyone else know of a better place to "T" into?
Thanks
Gristy
Offline davidgtrr34
Re: Where is the best place to take the Boost Gauge feed from?
« Reply #1 on: 25 September 2014, 12:58 »
Under the manifold connect it to the n249 on the pipe coming from the manifold to the n249. Its very accurate and won't interfere with anything
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline mcgee9t2
« Reply #2 on: 26 September 2014, 21:25 »
depends how accurate you want it to be.
if you want cock on accuracy etc then it needs to be manifold, however, I didn't have enough pipe, nor was I botherd about the .3psi (approx) that my boost guage may be out. therefore I went for the DV.
also bare in mind that most boot gauges aren't that accurate anyway and unless you have a digital boost guage that is very accurate your going to probly be about .3psi out anyway...
« Reply #3 on: 26 September 2014, 21:30 »
I ran mine from the FPR all ok.
Offline Dalo Harkin
« Reply #4 on: 30 September 2014, 12:27 »
Another from the FPR
Offline seanbmx
« Reply #5 on: 01 October 2014, 20:04 »
I did mine strait from the dv  :grin:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 01 October 2014, 20:52 »
mine is straight off the throttle housing as I don't have a line going to the charcoal canister any more
Offline TETSUOXGEZ
« Reply #7 on: 01 October 2014, 21:11 »
Well iam still feeding from the FPR, but as i have just found out... do not use cable ties to clamp vac hoses... use the tiny Jubalie clips far less chance or on air leak.
so diffinatly wont be running lean thanks to a bad tap in :p
Offline Dalo Harkin
« Reply #8 on: 03 October 2014, 12:24 »
I don't even cable tie mine, never had one come off yet...
Offline brewey
« Reply #9 on: 03 October 2014, 21:53 »
another vote from the fpr. Plus I've got tiny cable ties not clamps. No problems in 18'monthsish
2000 1.8T ARZ - OEM+
