Author Topic: 1.8t AUM Problem  (Read 2493 times)
Offline reedy20vturbo
1.8t AUM Problem
« on: 23 September 2014, 19:46 »
Hello all,
 This morning i went out to my car to go to work and it wouldnt start, i turned the key and it bogged like crazy for about 3 seconds then cut out, it did this twice and on the third time i had my foot on the throttle a little and it started up perfect as it would normally, i quickly plugged it in and i had the Fuel trim bank 1 (multi) system too rich code, i cleared it drove to work (about 10 miles) and plugged it back in and i had no codes, i came out after work it started up fine, i was heading up a slip road to the a30 and i had lost a lot of power i was in 3rd and felt like i was pulling in 5th from 40mph so i let off and on a few times and the power came back, , i have noticed over the passed few weeks theres been little misfires when idling but not when when driving just a big power lose, i do have weepy injector seals too that i have been meaning to do as there getting quite bad, do you think this is related? i only use vpower so its not to do with cheap fuel, but im stuck with what to do, any help will be much appreciated, thanks
Re: 1.8t AUM Problem
« Reply #1 on: 24 September 2014, 12:46 »
Bump
Offline davidgtrr34
« Reply #2 on: 24 September 2014, 15:41 »
When the car bogs with no power do you stiil have boost.
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
« Reply #3 on: 24 September 2014, 19:13 »
Yeah still get a dump and I can hear the turbo working :)
Offline davidgtrr34
« Reply #4 on: 24 September 2014, 19:34 »
Im not sure what the cause was but I had the same problem and the result was severe internal damage.
« Reply #5 on: 24 September 2014, 19:39 »
I've just disconnected my maf and it runs rune now! Looks like another new maf, that'll be it's 4th genuine vw one in 10k why is my car eating maf's? Haha
Offline davidgtrr34
« Reply #6 on: 24 September 2014, 21:04 »
You can get it deleted if you map it
« Reply #7 on: 24 September 2014, 21:49 »
Really? How does that work? :)
Offline Tezmax
« Reply #8 on: 25 September 2014, 19:28 »
Either your driving through a coal mine on your way to work every day or you have a birds nest in your air box.
No way should you be going through that amount of Maf's. Even the GSF, Euro carparts exchange last nearly 12months.
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
« Reply #9 on: 25 September 2014, 22:27 »
I have the s2000 filter, I have no idea why it does it, but I'll put a new one on it and it'll be fine again
