Author Topic: 2.0 8v AGG colour concept speedometer fault??  (Read 2282 times)
Offline johnleeuk59
« on: 21 September 2014, 21:44 »
Hi, im a new member to the site but ive been I reading a while...lol  I have a few annoying issues that I could use some help/advise with - firstly: the Speedometer (need I say more...lol) doesn't work, fuel gauge up and down randomly but the temp gauge is fine, the MFA only displays times, oil temp and outside temp !     I've checked all earths, all connections and changed the whole unit for one that definitely works,     any ideas??   pls...
Offline itavaltalainen
Re: 2.0 8v AGG colour concept speedometer fault??
« Reply #1 on: 21 September 2014, 21:55 »
I'd go with faulty wiring, faulty central electrics or faulty GND.
Offline johnleeuk59
« Reply #2 on: 22 September 2014, 12:46 »
Can't see anything wrong with wiring, do you have an idea what GND would cause this fault??  Also is there a separate speed sensor, I've always thought the crank sensor was also the speed sensor.. Thanks in advance
Offline gasketface
« Reply #3 on: 22 September 2014, 18:39 »
How would the crank sensor also be a speed sensor.The speed of the crank would change every time you changed gear ?.
« Reply #4 on: 22 September 2014, 19:59 »
does the fuel gauge also go wanky if you disconnect the sender unit in the fuel tank?
if yes then it's an electronic issue in the clocks i'd think.
if not then you have two separate issues; wonky fuel level sender unit and a faulty speed sender (which sits in gear box).
Offline johnleeuk59
« Reply #5 on: 25 September 2014, 03:26 »
sorry i ment engine speed, im jumping onto another topic without explaining 1st...my bad!!! when going through the "hidden options" in the MFA my engine speed stays at zero. I will check the above advice and get back to you.. Thank u
