Author Topic: Upgrade N75 or Manual Boost Comtroller?  (Read 1890 times)
Offline TETSUOXGEZ
  • "If in doubt, flat out"
« on: 18 September 2014, 23:29 »
So,
Upgrade the N75 or run a manual Boost Controller?
Offline rio_gti
Re: Upgrade N75 or Manual Boost Comtroller?
« Reply #1 on: 18 September 2014, 23:36 »
For what reason?
Offline TETSUOXGEZ
« Reply #2 on: 19 September 2014, 00:10 »
try and stabilze boost, ive already done the bypass mod, but i think the N75 is faulty :(
just looking for a quick fix for now as i have a MBC already, but i've heared there is a better N75 that i can install for running higher boost
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 19 September 2014, 13:56 »
N75 can be mapped via your ECU so there isn't really a plug and play version that will give you a happy ending
Offline golfyste
  • Project track car
« Reply #4 on: 19 September 2014, 16:59 »
There isn't a 'better' n75 they work depending on your map.
But they are all better then a mbc!
Ditch the mbc and plumb in a new n75.
If you want more power get a remap.
Offline Chris.
« Reply #5 on: 20 September 2014, 14:36 »
^^ what he said.
MBC usually make the car drive terrible part throttle
Click For Build Thread
Offline TETSUOXGEZ
« Reply #6 on: 21 September 2014, 14:36 »
Sounds good  :cool:
Thanks for the advice
re-map next month
