Poll
What would you keep?
Wheels
Brakes
Author Topic: Help, wheels or brakes?  (Read 1894 times)
Offline SI74
« on: 17 September 2014, 18:01 »
Wheels don't clear the brakes what would you keep. I haven't got time time to make parts fit any longer if it won't bolt on then it's not going to happen.  :grin:
Offline davidgtrr34
Re: Help, wheels or brakes?
« Reply #1 on: 17 September 2014, 18:24 »
Keep the wheels. There are plenty of walls around that you can use to stop you
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #2 on: 18 September 2014, 09:20 »
What wheels and what brakes?
Offline mcgee9t2
« Reply #3 on: 18 September 2014, 16:21 »
as above. if the wheels are really nice light weight etc with good tyres keep them, plenty of good break set ups that fit or almost fit standard alloys so will most likely fit what ever alloys you have.
if the break set up is really good and the alloys are some cheepo after market ones keep the break set up (so long as you can find a alloy to fit over the break set up)
if both breaks and alloys are good then its up to you, would you loose much performance by slightly de-rating the break set up?
Offline SI74
« Reply #4 on: 18 September 2014, 18:59 »
There both good but the wheels are wining.  Time to sell the brakes.
Offline shaft69
« Reply #5 on: 18 September 2014, 21:22 »
What wheels and brakes running??  I had same dilemma but worked around my brakes I have APracing front brakes and at £1800 new wheels work round them so running genuine R32 wheels now.
« Last Edit: 18 September 2014, 21:31 by shaft69 »
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline SI74
« Reply #6 on: 18 September 2014, 22:15 »
Cayenne 6pot Brembos with R32 discs or Porsche magnesium Techart split rims. I know that the brakes will fit with 15mm spacers with the R32 alloy and will fit the wheels I have with 32mm adapters but I don't think I want to be running that size of an adapter.  The brakes fill half the inside of the wheel lol.
