Author Topic: What's wrong with my KR  (Read 2162 times)
Offline dai-cymru
  • 1989 MK2 16V
« on: 16 September 2014, 17:20 »
Done a full engine rebuild on my golf but can't get it to run properly. When I bought it the car had been unused for 6 years. There was no compression on 2 cylinders.  That's all sorted now but when it starts it cuts out 2-3 seconds later . If you mess about trying and trying eventually it will run and warm up. When it was warm I set the ignition timing with the red lead disconnected from coil and it was ok idled a little low at 700 rpm but would run and rev all be it lumpy. I have replaced spark plugs dizzy cap and rotar and leads, the fuel system is untouched other than altering mixture to try get it going.  Fuel pump runs and have tested each injector and each delivers fuel. I have Bosch FR6 DC + supplied by euro car parts on the reg and that's what I took out  the Haynes suggested Bosch FR56 plugs. Any ideas what's wrong with it as have spent a fortune rebuilding engine and need it to run!!
Offline raferackstraw
Re: What's wrong with my KR
« Reply #1 on: 16 September 2014, 19:57 »
on cold start the cold start injector should run for up to 10secs to give that initial enrichment for starting, once running then its the warm up regulator that takes over enrichment until engine is warm. if its been unsed for 6yrs then the possibility is there is gunk in the fuel injection system.
you will need a fuel pressure test gauge kit to properly check fuel pressures during start up and warm up, try this link for understanding kjet
http://www.volvoclub.org.uk/tech/fuel_injection/k_jetronic.shtml
try this as well
http://books.google.co.uk/books?id=fVm0HYHJr4gC&pg=PA102&lpg=PA102&dq=bosch+cis+fuel+injection+system&source=bl&ots=ljW0VuJS0P&sig=uYRI8CtDljBHZR8sTHhb_1Xo5T4&hl=en&sa=X&ei=IIkYVK_7GNGO7Qas6IGIAw&ved=0CCYQ6AEwATgK#v=onepage&q=bosch%20cis%20fuel%20injection%20system&f=false
« Last Edit: 16 September 2014, 20:04 by raferackstraw »
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline dai-cymru
  • 1989 MK2 16V
« Reply #2 on: 16 September 2014, 22:17 »
Thay great info. Thanks. Think I best start going through the fuel side step by step.
Offline Diamond Hell
  • Opinions я Us
« Reply #3 on: 17 September 2014, 17:06 »
mechanical metering are not the most reliable things.  I reckon you will be spending some time and money with an expert to get it running well, if it's been apart and isn't running right.
Good luck!
Offline dai-cymru
  • 1989 MK2 16V
« Reply #4 on: 18 September 2014, 08:19 »
The engines been fully rebuilt but fuel injection hasn't except new filter & fresh fuel. Can you convert the fuel system to different more reliable system?  Or does anyone know a K- jet specialist in a South Wales?
  • Opinions я Us
« Reply #5 on: 18 September 2014, 12:14 »
Not easily and no.  Sorry.
Ask on ClubGTI - there are some K-Jet lovers there.
