Author Topic: and.... what are peoples set up on forge 008  (Read 1772 times)
Offline davemk4
« on: 11 September 2014, 15:33 »
Running a stage 2 ecu and upgraded  to a forge 008 and had forge 007 on with yellow spring. Now i tried car with forge 008 with yellow seemed abit weak. Put 1 spacer in abit better. Put 2 in and now seems to hit boost of 23/24/25psi which seems high for a stage 2.
What is a average stage 2 psi?
And what are people running on a 008?
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Dalo Harkin
Re: and.... what are peoples set up on forge 008
« Reply #1 on: 12 September 2014, 13:07 »
Its not excessively high, mine is a stage 2 and boosts between 22-25 psi. on a 007p though with a yellow spring
Offline davemk4
« Reply #2 on: 12 September 2014, 13:30 »
Same as me pal. But since changing to 008 yellow spring seems to drive different. In 3rd at 4000rpm my boost starts dropping below 20psi quite quick sometimes im not hitting 21/22?? But when tried with 2 shims car felt bogged down and was boosting to 25psi but it actually felt slower?
Offline Scott D
« Reply #3 on: 12 September 2014, 16:15 »
25psi is a lot for a typical stage 2 map and boost will tail off quickly after 4/4.5k
Could be leaking causing over boost to compensate
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline davemk4
« Reply #4 on: 12 September 2014, 18:57 »
Thing is is a amd stage 2 map from guy on here and i too thought 22-24psi high on k03s. I might leave the yellow spring in it untill actuator replaced and check pipes etc make sure all are good. Then take the shims to rtech incase needed?
