Author Topic: What is the common porsche break upgrade  (Read 2390 times)
Offline Mk2_tel
« on: 09 September 2014, 22:30 »
Front brakes 4 pot is it 323mm discs what porsche is that 996?
And is it a good upgrade at the right price?
Where would you get pads from etc cheers
« Last Edit: 09 September 2014, 22:37 by Mk2_tel »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: What is the common porsche break upgrade
« Reply #1 on: 10 September 2014, 18:21 »
Porsche 996 fronts can be used on the 312mm or 323mm discs depending on carrier choice.
I think they need custom pads, couldn't tell you where to get them from though. Also please look into this mod as the rears have nearly the same part number of the fronts but less braking force than the standard VW setup!
Offline Mk2_tel
« Reply #2 on: 10 September 2014, 20:49 »
I can't seem to find a part number I have this 20524800 and 20524900
Offline Mr-B
« Reply #3 on: 10 September 2014, 22:43 »
996 fronts / 996 turbo rears
the part numbers for these are 996.351.425 & 996.351.426 (996 fronts) or 996.352.425 & 996.352.426 (996 turbo rears)
piston sizes for the 996 turbo rears are 28mm and 30mm, and these use a slightly larger pad then the rest of the porsche rear calipers.
piston sizes for the 996 fronts are .................
these require a 28mm disc, there is a 330mm disc available which is much taller than the 312mm or 325mm disc and means theres less chance of needing a spacer to clear the caliperss
for the bigger calipers 429&430 and 431+432 then you need a 34mm discs.
Mk4 AGU 1.8T, JOM Coilovers, Creation Motorsports TIP, FMIC 2.5", WhiteLine ARB, WhiteLine Droplinks, Brembo Drilled & Grooved F/R, Forge Spacers, K&N Oil Filter, Forge Catch Tank, ECS Dogbone Mount, Custom Side Exit 2.5" (Work In Progress)
Offline golfyste
  • Project track car
« Reply #4 on: 12 September 2014, 09:33 »
Just use Cupra r brembos with the 323 disc??
Offline Mk2_tel
« Reply #5 on: 12 September 2014, 09:41 »
Lovely great info cheers guys
