Author Topic: Golf MK4 Dash Removal???  (Read 2796 times)
Offline Mr-B
« on: 09 September 2014, 20:27 »
Need some advice on removing my dash.
I have a nice new flocked dash ready to install. I have seen videos on how to remove the vents. light switches ect ect. but I have not been able to find any advice on removing the dash totally.
Do i need to remove the steering wheel? if so what method is best and what should i do about the airbag? Also what about the passenger side airbag?
Is there any guides to removing a full dash?
Thanks!
Mk4 AGU 1.8T, JOM Coilovers, Creation Motorsports TIP, FMIC 2.5", WhiteLine ARB, WhiteLine Droplinks, Brembo Drilled & Grooved F/R, Forge Spacers, K&N Oil Filter, Forge Catch Tank, ECS Dogbone Mount, Custom Side Exit 2.5" (Work In Progress)
Offline davidgtrr34
Re: Golf MK4 Dash Removal???
« Reply #1 on: 09 September 2014, 20:51 »
The steering wheel needs to be removed. You can remove the airbag without disconnecting the battery but when your fitting the airbag back in always disconnect the battery
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline Mr-B
« Reply #2 on: 09 September 2014, 20:57 »
Thanks for the tip, Are there any guides showing the steps to removing all the parts?
Offline old_n07
« Reply #3 on: 23 September 2014, 16:04 »
Yes, have a look at this one
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
« Reply #4 on: 26 September 2014, 21:30 »
Complete ballache, when we did the Skoda Octavia to replace the heater matrix it took around 4 hours to get the dash out, Golf mk4 will be the same, a lot of the bolts are hidden.
