Author Topic: mk4 1.8t coolant fans not working  (Read 3691 times)
Offline barrym381
« on: 06 September 2014, 21:08 »
mk4 1.8t coolant fans not working tried fuses new sensors even swapped fans over from my other 1.8t that i know work an they still did nothing  :headbang: they work if i bridge the switch at lower rad
Offline sharki786
  • GOT BOOST??
Re: mk4 1.8t coolant fans not working
« Reply #1 on: 06 September 2014, 21:40 »
Have you checked the fuse on the fan control mod? If they fine then check the temp sensor or vag com it.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline barrym381
« Reply #2 on: 06 September 2014, 21:59 »
tried both fuses on top of the battery  :sad: still nothing
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 06 September 2014, 22:21 »
Check on vagcom
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 06 September 2014, 22:22 »
Could it not be the temp sensor?
*****MK4 GTI T*****
Offline barrym381
« Reply #5 on: 06 September 2014, 22:23 »
new 1 fitted  :wink:
Offline sharki786
  • GOT BOOST??
« Reply #6 on: 06 September 2014, 22:30 »
Genuine? Could be a faulty new1?
*****MK4 GTI T*****
Offline barrym381
« Reply #7 on: 07 September 2014, 10:01 »
yes a genuine 1 was used  :smiley:
Offline Dalo Harkin
« Reply #8 on: 12 September 2014, 13:20 »
do you drive like a girl  :tongue: :grin:
Offline james2
  • No scammers please.
« Reply #9 on: 12 September 2014, 14:17 »
Have you changed the thermostat.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
