Author Topic: mk4 1.8t coolant fans not working  (Read 3693 times)
Offline Bellend
Re: mk4 1.8t coolant fans not working
« Reply #10 on: 12 September 2014, 17:34 »
There is a fan control module under the battery tray.
This is probably your issue. You need to find one that matches part numbers as the pins are different on different models. I'm just about to break up a 2001 1.8T with manual air con.
Where all my moneys went.
Online barrym381
« Reply #11 on: 13 September 2014, 15:29 »
do you drive like a girl  :tongue: :grin:
yes a german 1  :wink:
Have you changed the thermostat.
yes new genuine 1 fitted  :smiley:
tried this with swapping the part from my other 1.8t still no luck  :smiley:
Offline Bellend
« Reply #12 on: 13 September 2014, 20:22 »
That's incredibly odd. Have you checked power and earth at each stage?
Online barrym381
« Reply #13 on: 13 September 2014, 20:40 »
tried this too  :smiley:
Offline Bellend
« Reply #14 on: 13 September 2014, 20:46 »
At which stage is the power not getting through?
Bridge temp switch and then check there has got to be a break in the circuit somewhere.
