Author Topic: Fitted a K04 hybrid on AGU now over boosting to hell  (Read 2127 times)
Offline gti_shaun
« on: 04 September 2014, 21:49 »
Hi all, Ive got a hybrid K04 fitted and I'm getting it mapped next week, took it for a little drive to bead brakes in as they are all new and booted it just to see what boost level was, I won't be doing again as it went off my guage (over 2 bar) needles to say it span both wheel on third gear(LSD)
My question is, could this be some thing I may have done even though I'm positive the n75 is piped up correct as I marked it up, the actuator has a 3 turn preload, or will this be turned down on the map, I remember nick@ rtech saying he left a aggressive map on from when I was having boost issues with my old turbo, could it be in the map, as obviously a k03s can only boost 1.6 bar max so it wasn't going to Super boost....
« Last Edit: 04 September 2014, 22:48 by gti_shaun »
Offline gti_shaun
Re: Fitted a K04 hybrid to AGU now over boosting to hell
« Reply #1 on: 04 September 2014, 22:04 »
I will test the actuator tomorrow with the mity vac and make sure the diaphragm isn't bolloxed
Offline Dalo Harkin
Re: Fitted a K04 hybrid on AGU now over boosting to hell
« Reply #2 on: 05 September 2014, 12:27 »
Not true, when I was having issues my K03s boosted over 1.7 bar
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 05 September 2014, 20:47 »
if it has a 1bar actuator like most k04 hybrids i've seen, i'd say that's normal behaviour with an aggressive map written for a k03s. unplug the n75 and stay off boost until its mapped to suit the new turbo
Offline gti_shaun
« Reply #4 on: 05 September 2014, 21:42 »
Thanks for the replys, Ben from rtech rang me today and said the same thing, wish I gone all the way and done rods and everything now because I love the 2+bar ha ha
Offline shaft69
« Reply #5 on: 06 September 2014, 19:04 »
Def need rods with k04 hydrid like half a job if rods not done and won't get full potential from it when mapped. What k04 hybrid you got??
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
