Author Topic: Leak in my fuel tank :(  (Read 2977 times)
Offline Bfstrachan
« on: 04 September 2014, 12:21 »
Are there any threads you know of showing how to replace the fuel tank in a AUM code? First glance seems like a pretty big undertaking! Any help would be appreciated. If anyone has a tank or knows of one in Scotland (Aberdeenshire to be specific) please give me a shout. Are the tanks model specific or are they same through the mk4's?
Thanks.
Offline MoMartin
Re: Leak in my fuel tank :(
« Reply #1 on: 04 September 2014, 12:24 »
can't it be patched up? or is that not a good idea? obviously don't weld anywhere near it though.
Offline Dalo Harkin
« Reply #2 on: 04 September 2014, 12:31 »
I'm pretty sure its just held on with a metal strap in a recess, and that it attaches to the fuel pipe filler, never taken one off a golf but most other cars are like this too
Offline WadGTI
  • Golf GTI'er
« Reply #3 on: 04 September 2014, 12:38 »
I did my tank on my old mk3 golf. DOn't tihnk there the same, however I don't think the process would differ.
You can do it yourself, however I would have 2 people as it makes it a bit easier. On the mk3, the filler neck was all one piece on the tank, so removed the straps and angled the filler neck with the tank out and it dropped.
I got my tank from my mate how does vw spares in Bonnybridge. He sold me a good tank from a vr6 for £40 as VW wanted hundreds of $$.  If it is close to you, I can check to see if he has a mk4 lying around.
Offline Bfstrachan
« Reply #4 on: 04 September 2014, 12:54 »
Looks like it's was patched in the past And has come undone. Don't know if I want to try patching again? Guessing the tank would need to come out to make a proper job as the leak is on the underside and guessing the tank would need to be bone dry before any attempt to patch could be done?
Offline Bfstrachan
« Reply #5 on: 04 September 2014, 12:57 »
Had a quick google and seems like the rear axle has to be dropped? Guessing it's not simply undoing the straps etc...
Offline WadGTI
  • Golf GTI'er
« Reply #6 on: 04 September 2014, 13:56 »
Sorry mate, I havn't done it on the mk4. However on the mk3 no axle had to be removed. The tank on the mk3 was rather large in area size and did not have alot of depth as I can recall.
Offline Bfstrachan
« Reply #7 on: 04 September 2014, 15:56 »
No worries, I am just going to take it to a garage - made an enquiry at local and quoted £50-£60. Just need to source a tank now :) Is Bonnybridge down Glasgow way? If u could check or give me contact info for your mate, that would help.
Thanks
Offline barrym381
« Reply #8 on: 04 September 2014, 21:55 »
there is a few breaking in here sure a couple of them are not far from you  :smiley:
http://www.scottishvag.net/viewforum.php?f=211
Offline Bfstrachan
« Reply #9 on: 05 September 2014, 00:00 »
Thanks for the tip! Didn't know this existed. Have replied to a couple of adds - fingers crossed!
Thanks.
