Author Topic: Do I need a updated fuel pump?  (Read 1815 times)
Offline gti_shaun
« on: 02 September 2014, 17:58 »
If some have read my previous post I'm getting my AGU mapped soon, at the time I did all the mods 18 months ago(been stored away) I'm sure I read the standard pump was good for high HP anyone know what HP is recommended to be up rating the in tank fuel pump?
Offline mcgee9t2
Re: Do I need a updated fuel pump?
« Reply #1 on: 02 September 2014, 18:37 »
no. not unless your going for around 300+bhp.
if you have a spare bit of cash, buy a new fuel pump from vw as over time they do deteriorate and may find that its not working as efficient as it should.
however, speek to your mapper, he will tell you exactly whats best for you to do (thats if he knows his stuff).
Offline Scott D
« Reply #2 on: 03 September 2014, 00:17 »
No harm in using a new pump or uprate for piece of mind
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline gti_shaun
« Reply #3 on: 03 September 2014, 09:03 »
Does the r32 one direct fit with more flow? I'm thinking the quickest option aswell
Offline rio_gti
« Reply #4 on: 03 September 2014, 12:20 »
leon cupra r is straight swap  :wink:
Offline golfyste
  • Project track car
« Reply #5 on: 06 September 2014, 18:58 »
As said you wanna replace it really as they can start to fail at lower go due to age.
Just get a sytec one. £60 and good for 500+hp. More then enough!
