Author Topic: Tyre pressure warning  (Read 4462 times)
Offline fredgroves
« on: 02 September 2014, 09:22 »
So the other day I saw my first tyre pressure warning - nothing too odd about that you might think...
But it activated for all 4 tyres simultaneously - and no, I hadn't driven over a stinger (they weren't even chasing me *ahem*  at the time)
Checked all the pressures, they are fine, reset the system and everything's good since.
Anyone else had it spaz out like this?
Fred
Offline mcmaddy
Re: Tyre pressure warning
« Reply #1 on: 02 September 2014, 09:24 »
It does this occasionally.
Offline fredgroves
« Reply #2 on: 02 September 2014, 09:29 »
Thanks - I wondered if it was to do with a rapid temperature change or something? It had got really cold and wet the other afternoon up here.
Offline JoeGTI
« Reply #3 on: 02 September 2014, 10:21 »
Mine did it over the weekend. Checked the pressures and all seemed fine, so I just reset it too. It'd be useful if it would tell you which tyre is the problem...
Offline mcmaddy
« Reply #4 on: 02 September 2014, 10:25 »
It does tell you if you have a problem with a specific tyre. In this case it sounds like the system just needed a reset.
Offline fredgroves
« Reply #5 on: 02 September 2014, 10:39 »
Yeah someone I know had it go off once before, but warning about a specific tyre, so I guess it does work.
Fred
Offline JoeGTI
« Reply #6 on: 02 September 2014, 14:23 »
Oh really? Mine just gave a generic warning about the tyre pressures but definitely didn't specify which one. The graphic of the car was displayed on screen with all tyres highlighted!
Offline mullermn
« Reply #7 on: 02 September 2014, 14:54 »
Mine went off with a non specific warning the first time I did a long journey after changing the wheels and tyres. I reset it and haven't had any repeat since.
Offline mcmaddy
« Reply #8 on: 02 September 2014, 15:42 »
It definately detects loss of pressure and tells you which one as mine told me i had a problem with osr. It works from the abs sensors so if both back tyres go down together it wont dtec a problem.
Offline gazmondo35
« Reply #9 on: 02 September 2014, 16:16 »
Just out of curiosity what should the tyre pressure be, when my warning went of I checked & found I had 42psi which seems very high.
Mk7 golf R DBP
MK7 golf gti pp red (sold)
