Author Topic: coilover help needed please  (Read 4023 times)
Offline viperjsy
« on: 22 August 2014, 01:28 »
hi what do I need to put on here please thank you
I know I need Suspension Strut Top Mounts+ Bearings x2 but is there any thing else I need
« Last Edit: 22 August 2014, 01:31 by viperjsy »
Offline MoMartin
Re: coilover help needed please
« Reply #1 on: 22 August 2014, 11:34 »
This isn't essential, but putting copper grease on the coil would be a good idea
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 22 August 2014, 11:59 »
You need some NEW top mounts just incase your old ones fail. As lowering a car will put ALOT of strain on other suspention componants.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline viperjsy
« Reply #3 on: 22 August 2014, 16:23 »
thank you for your help
wouldent the copper grease destroy the dust cover
« Last Edit: 22 August 2014, 16:29 by viperjsy »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 22 August 2014, 16:44 »
new bearing and top mount, fit to the car then cap in engine bay followed by top nut, then the black cover
Offline viperjsy
« Reply #5 on: 22 August 2014, 16:51 »
thank you Wazzzer
Offline 1.8Tgolf_Chris
  • Mk4 1.8t AUM
« Reply #6 on: 22 August 2014, 22:54 »
+ just remember to use the old slim inner top nut from your stock struts
Offline viperjsy
« Reply #7 on: 25 August 2014, 00:28 »
do I use the aluminum spacer or leave it off
Offline viperjsy
« Reply #8 on: 27 August 2014, 18:00 »
hi do the Bearings just slide on or screw on thank you
  • Mk4 1.8t AUM
« Reply #9 on: 27 August 2014, 19:10 »
use the front coilovers how they came in the box, with nothing on the top thread the bearing just rests on and so does the upper rubber mount, then you screw the inner strut nut down- Fit the coilover to the car then the top hat goes on in the engine bay, and the final top lock nut
