Author Topic: ABF 16v will not rev above about 5k after being sat for a few months  (Read 5001 times)
Offline Adezmk3
Hi,
Unfortunately I'm not able to get the fault codes read. I've not had a chance to check if the timing belt has moved but I am pretty sure it hasn't. The car was parked up for about 2-3 months unstarted. In that time the ISV did get stuck so it wouldn't idle (this I have now freed up). Before it was left it definitely would rev cleanly to the red line (this I am 100% certain of) so I am more inclined believe its a dodgy sensor somewhere.
The fuel pump and ECU relays had recently been replaced, the crank position sensor, cambelt, waterpump, ECU coolant temp sensor, breather hoses, plugs etc and the car ran perfectly fine after this.
Any other ideas? It's not really 5k, its about 4.5k that it starts to struggle.
If anybody in the Hinckley area has vagcom and they could scan for me that would be great. I have tonnes of mk3 spares (currently have 5 mk3s to my name plus loads of bits and bobs from a few I have broken so would happily trade scanning for some parts).
cheers
Offline danmusic24
Same prob years ago take the battery off and fully charge it.
Might sound odd but worked for me
Offline xAntiVenxm
leaving this key popping aside..
i'd do what makes sense to me and thats scan it with vag-com. see what error codes pop up.
sounds like it's your hall sensor.
if you check the mk3 maintenance common issues thread there's a section on this.
Offline Adezmk3
Which hall sensor do you suspect? The only one I am aware of on the ABF is the crank position sensor.
Thanks
Offline xAntiVenxm
Thanks
look in the mk3 maintenance section, there's a list of the common problems. It shows the hall sensor in a similar area as the crank angle sensor, but not the same thing (i think)
Offline xAntiVenxm
you also need to have the cam belt inspected.. if it's even one tooth out, the engine goes into safe mode and won't let you rev high.
