Author Topic: Left hand control stalk button not used?  (Read 5016 times)
Offline double0
« on: 11 August 2014, 19:38 »
So my GTI PP is coming up for it's first annual service (less than 4k miles but it's included in the paid for 3 year plan so why not)!  Anyhow something I will get checked at service if can't confirm here is re. the button on the left hand control stalk which I thought would be used for cruise control?  Is it not used if you have the multifunction wheel on GTI as mine seems to not do anything?  Cruise etc all works fine using the wheel controls.  Appreciate if someone could check on theirs?  Cheers  :smiley:
Offline marnie
Re: Left hand control stalk button not used?
« Reply #1 on: 11 August 2014, 21:04 »
It's cruise control cancel.
Mk7 GTI 5 Dr
Offline wardtowers
« Reply #2 on: 11 August 2014, 21:11 »
It should bring up the Front Assist options in the MFD when you press it, allowing you to switch it on or off.
Golf GTD, DSG, Black, Keyless
Ordered 02/05/2014 - BW Confirmed 16/05/2014 (BW24) - In Transit 15/06/2014 - In the UK 24/06/2014 - Being Delivered 10/07/2014 (10 weeks order to delivery)
Offline double0
« Reply #3 on: 11 August 2014, 21:28 »
Ok cheers - will check to see if it does anything re. front assist and if not get sorted at first service.
Offline kevinm
« Reply #4 on: 11 August 2014, 23:38 »
That button also brings up the option to disable lane assist if you have it fitted.
Current: His: 2020 M340i   Hers: 2019 GTD
Previous:
2014 GTI PP DSG
GTI ED30 DSG
Offline KyleB
« Reply #5 on: 11 August 2014, 23:58 »
Pressing it on my car does nothing. I thought it'd only display if you had lane assist.
Offline kevinm
« Reply #6 on: 12 August 2014, 07:57 »
This is what I get:
Previous:
2014 GTI PP DSG
GTI ED30 DSG
Offline double0
« Reply #7 on: 12 August 2014, 12:10 »
Cheers - looks like that might be the case then i.e only has a function if more than one assist option?  Thanks Kevin's for taking the time to grab a pic of yours with lane assist.
Offline KyleB
« Reply #8 on: 12 August 2014, 13:28 »
Kevin your dials look so much cleaner than the ones that have MPH on them :(
Offline kevinm
« Reply #9 on: 12 August 2014, 13:33 »
Ya having both scales on the speedo makes it look very cluttered. IIRC, vw did a speedo with just mph on it for a while on the mk6
Previous:
2014 GTI PP DSG
GTI ED30 DSG
