Author Topic: Left hand control stalk button not used?  (Read 5020 times)
Offline KyleB
Re: Left hand control stalk button not used?
« Reply #10 on: 12 August 2014, 14:46 »
Kevin your dials look so much cleaner than the ones that have MPH on them :(
Ya having both scales on the speedo makes it look very cluttered. IIRC, vw did a speedo with just mph on it for a while on the mk6
Yeah I was hoping that the dials would just have MPH with an option for KPH in the MFD.
Offline p3asa
« Reply #11 on: 12 August 2014, 16:52 »
Pressing it on my car does nothing. I thought it'd only display if you had lane assist.
Cheers - looks like that might be the case then i.e only has a function if more than one assist option?  Thanks Kevin's for taking the time to grab a pic of yours with lane assist.
No. I don't have lane assist but still get Front Assist coming up if I press the left hand stalk button.
Offline dippy_x
« Reply #12 on: 12 August 2014, 22:01 »
Same here.  Just get the option to disable front assist when I press that button.
On Order: 02/05/13
GTD: Carbon Grey, Winter Pack, Keyless, High Beam Assist, Park Assist, Rear View Camera, Furry Dice
Collected: 06/11/13
Offline double0
« Reply #13 on: 04 October 2014, 08:54 »
Mentioned the problem at first service and got it sorted with a replacement part.  Pressing the stalk button now brings up Front Assist.  Kyleb - think you said yours didn't function either so could be a known fault.
« Last Edit: 11 October 2014, 15:38 by double0 »
Offline KyleB
« Reply #14 on: 04 October 2014, 21:39 »
Mentioned the problem at first service and got it sorted with a replacement part.  Pressing the stLk button now brings up Front Assist.  Kyleb - think you said yours didn't function either so could be a known fault.
Yeah mine doesn't do anything so I'll speak with the garage. Cheers.
