Author Topic: Boot handle/badge  (Read 3636 times)
Offline markos
  • kämpfen und siegen
Boot handle/badge
« on: 30 July 2014, 19:04 »
hey, just wondered if anyone else has had this problem as i think it might be a common one.
basically the vw badge that is the boot catch/handle has corroded (has a kind of white rust almost)
i've read elsewhere this can be replaced in 2 ways, either do the whole handle which will be a £120 part and the labour on top of that, or just replace the plastic badge part.
has anyone had this problem and solved it by just replacing the badge part (hopefully it will be a £20 part and a job i can do myself on the drive)
thanks in advance
Offline bbewekim
Re: Boot handle/badge
« Reply #1 on: 31 July 2014, 17:50 »
I'd be interested in this too.
Offline th3_f15t
« Reply #2 on: 31 July 2014, 18:58 »
Not so much had the usual "white worn" corrosion problem, but my girlfriend swapped just the badge on hers for a black one (opposed to the chrome one as standard). So yes, you can do it for £20, just really clean the surface before you replace a new badge.
Moving over to Flickr, sorry for the broken picture links!
Offline markos
« Reply #3 on: 31 July 2014, 20:59 »
interesting... went into vw today and they said it can't be done and needs to be the whole unit! any chance you could post a link to the badge she bought and how easy it was to replace?
thanks!
Offline bobotheclown
« Reply #4 on: 31 July 2014, 22:06 »
I think it depends on the type of boot badge. If you have a flat badge here is how to remove it
http://www.vwgolf.net.au/showthread.php?832-DIY-Remove-Rear-VW-Emblem&p=23630
Offline markos
« Reply #5 on: 01 August 2014, 14:25 »
awesome, thanks for that link. managed to get the old badge off using the credit card technique (really did destroy it though so if anyone else is going to attempt it go for an old one!)
so, now i need to replace what i've taken off with a new one. anyone have a link to what i need? had a quick look on ebay and could only find ones for mk4s
have attached a couple of images of what i took off...
Offline th3_f15t
« Reply #6 on: 02 August 2014, 15:03 »
Look carefully on the rear and you'll find the VW part number. Use this in eBay or visit a main dealer to replace with a genuine item.
Offline markos
« Reply #7 on: 22 August 2014, 21:50 »
so the mk4 badge fits the early mk5 handle, i've bought one off the bay and stripped it down to 3 parts. i now need to attached the chrome vw part to the boot handle. has anyone else done this mod and what do you use to attach it?
