Author Topic: 1.8T 180 Vacuum/breather hoses  (Read 2320 times)
Offline gazman83
  • 2003 Golf GTi 1.8T 180
« on: 22 July 2014, 07:42 »
Hi everyone, I'm new to the GTi forum. I have recently purchased a 1.8T 180 AUQ, the previous owner has dropped in an induction kit and done a poor job of installing a catch can.
In the process of installing the catch can they have left various connections either plugged with a bolt of some description or just left open.
I want to put the engine bay back to standard as I'm worried about how the engine is being effected.
I have all the original breather hoses to re-install but unfortunately I haven't a clue where they all go.
Would it be possible for
someone with the same or very
similar engine to take photos of their engine bay and post them
on here so that I have some photos to work off when re installing all the hoses?
I could do with detailed photos of the inlet manifold, header and the area around the stock recirculating valve.
I will post some pictures of how it currently looks, any feedback welcome.
Thank you in advance
« Last Edit: 22 July 2014, 08:31 by gazman83 »
Offline gazman83
Re: 1.8T 180 Vacuum/breather hoses
« Reply #1 on: 22 July 2014, 07:44 »
Sorry I meant to say this is a 2003 MK4
Offline gazman83
« Reply #2 on: 22 July 2014, 16:10 »
can anyone shead any light on this? working on the car this evening.
Thanks
Offline shaft69
« Reply #4 on: 25 July 2014, 21:44 »
1st thing done on my golf removed the lot and fit catch can boost leak in 3 different places, then just ripped it all out.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline gazman83
« Reply #5 on: 25 July 2014, 21:59 »
Thanks for the pics!
Finally for round to sorting it all this evening. I have to say the engine seems to run a lot quieter and smoother without the catch can in.
Checked all the pipe work that was installed with the catch can and it was almost totally blocked with gunk, I suspect the tubing was too small to begin with.
The previous owner had also bypassed the N249 valve, I've left this as it was because everything I have read points towards a much smoother application on boost.
Installed my boost gauge today as well, boost is hiding steady at around 0.6 bar, sounds about right as standard psi is 7-8.
I've ripped out the induction kit and put the air box back in with a performance filter, seems to have done the trick, engine was suffering with the heat produced from the engine and the hot weather as the standard intercooler isn't exactly the biggest on this car.
