Author Topic: Urgent lock housing removal help!  (Read 2472 times)
Offline golf cabry
« on: 21 October 2003, 10:02 »
Can anyone tell me how to remove the housing around the steering column that holds the lock cylinder and ignition/starter switch? I have removed the steering wheel and switches but cannot remove the housing unit for some reason. Cannot see what is holding it on. Any help welcome!
Offline golf cabry
Re:Urgent lock housing removal help!
« Reply #1 on: 21 October 2003, 23:35 »
Anyone?????
Offline Dizzie
  • Make friends with your fast
« Reply #2 on: 22 October 2003, 10:44 »
measure 12mm and 10mm down the barrel from the casting mark. Now drill a 3mm hole. Get it right and the barrel pops out.
Offline golf cabry
« Reply #3 on: 22 October 2003, 12:54 »
Need to get the housing for the barrel off the steering column, not the actual barrel Dizzie. Cheers for help though!
Offline Dizzie
« Reply #4 on: 22 October 2003, 15:46 »
oh. isn't there 2 6mm allen bolts underneath. once they're undone the alloy bit should slide off providing you have removed all the bits in the way like wheel and stalks. I can't think of anything else in the way at the mo.
Offline richandhazel
