Author Topic: GTI APR map release info from the USA  (Read 29322 times)
Offline GrahamFR
Re: GTI APR map release info from the USA
« Reply #60 on: 31 July 2014, 11:51 »
i am uber jealous, where feck is stage 2!! think im going to have mine done by shark though
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline monsta
« Reply #61 on: 31 July 2014, 12:26 »
I'm sure Stage 2 will be on the way, they seem to put an incredible amount of testing into these things which is very reassuring!
Might have to go and have a lunchtime drive  :cool:
Offline monsta
« Reply #62 on: 31 July 2014, 14:09 »
Had a lunchtime blast up the dual carriageway, 6th gear just goes and goes, crazy.
You have to be really controlled in 1st/2nd or the wheels are gonna spin.  Third gear though, away you go! And boy does it go.  I can see why they keep 300 HP to the 4WD cars.
Very impressed.  :laugh:
Offline wigit
« Reply #63 on: 31 July 2014, 14:58 »
just beware of doing those 6th gear pulls as that is what will kill your clutch, dropping a gear will help as you can use the power rather than the torque
Offline Ian.C
« Reply #64 on: 31 July 2014, 16:12 »
Montana have you had any tuning boxes on your Gti? Hoping for a comparison between the two
I should be able to give you a comparison on Monday....ill post some thoughts next week.
Ian
3 Door - Pure White - PP
Offline monsta
« Reply #65 on: 31 July 2014, 21:38 »
Good tip, thanks. Thought higher gears would be safer  :smiley:
Offline Black oil
« Reply #66 on: 02 August 2014, 14:54 »
Look forward to more updates on this as I have enquired and very likely to have this installed.
Monsta - were you advised to add an uprated cooler (intercooler?) when available?
Speaking ( via mail ) with the APR agent they seemed to think this best as the temps could rise enough for the engine to go into 'safe mode'!
Having said that they said Stage 1 will run ok as it is!
Cheers for any info.
Mk7 Gti.5dr.Deep black pearl,PP,acc,nav pro,pano roof,leather,winter pack,dynaudio.Rather nice.
Offline remlapeel
« Reply #67 on: 02 August 2014, 15:29 »
It sounds like APR are running this very close to the limits of the engine!
2015 MK7 Golf R 3 door, DSG, lapiz blue, 19" wheels, winter pack, keyless entry, dynaudio and high beam assist.
Offline Black oil
« Reply #68 on: 02 August 2014, 15:54 »
Well I don't think they would release a fundamentally flawed product for what is essentially general consumer use.
Maybe it's a track day reliability thing. I mean I have read that people are noticing eng temp drops in general use seemingly without an upgraded cooler so the engine can't be under huge stress!
Personally i'd be more concerned about the clutch.
« Last Edit: 02 August 2014, 15:55 by Black oil »
Offline remlapeel
« Reply #69 on: 02 August 2014, 16:34 »
Yeah cooling wouldn't be a major concern. The clutch wouldn't be a cheap fix if it did decide to die.
