Author Topic: debating arbs  (Read 1675 times)
Offline 1.8Tgolf_Chris
  • Mk4 1.8t AUM
debating arbs
« on: 08 July 2014, 22:26 »
Really getting annoyed with the arb rubbing on D/S but dont really want the job of fitting another one got no motivation to fit it as it was such a b!tch to fit new arb bushes not so long ago, and then its a fact of having the subframe aligned once u fit the new arb?
Now my misses is driving, my car wont be used as often so im thinking lowering it a further 20mm and just sack off the arb  :smug:
The roads where I live i rarely go over 30mph let alone highspeed corners so i doubt ill notice without one, decision to make
Offline barrym381
Re: debating arbs
« Reply #1 on: 08 July 2014, 22:31 »
your car will drive terrible without an arb  :whistle:
Offline Scott-R
  • GoT BoosT!
Re: debating arbs
« Reply #2 on: 08 July 2014, 22:54 »
Really?  :laugh:
Golf GTI ... What else would you have?
  • Mk4 1.8t AUM
Re: debating arbs
« Reply #3 on: 09 July 2014, 00:51 »
i appreciate ur comments, I feel it will handle sh!t 2 inch of the ground anyway?
Offline Scott D
Re: debating arbs
« Reply #4 on: 09 July 2014, 01:59 »
I've gone from a cut arb to TT bar which has made a noticeable difference - seems a lot more stable when making fast directional changes and much sharper turn in although had a full wheel alignment done soon after.
down about 70/80mm and on flat smooth roads handling is epic however all is different on country roads with plenty of camber and not in a good way  :grin:
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
