Author Topic: Some fault code help...  (Read 6374 times)
Offline dom
  • Back in a Mk4
« on: 07 July 2014, 22:23 »
Hey,
I've just bought an 05 plate Gti and gave it a quick scan with Vagcom, after clearing the old codes there are the ones that remained:
Quote
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 AB
   Component: ClimatronicPQ35 066 0404
   Shop #: WSC 00000 000 00000
   VCID: 67DD5D1756980F26359-8032
2 Faults Found:
00797 - Sunlight Photo Sensor (G107)
            010 - Open or Short to Plus - Intermittent
00709 - Sunlight Photosensor 2 (G134)
Quote
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AJ
   Component:    KSG              0401
   Coding: 19C802087F2D8D0D485AC69010CC
   Shop #: WSC 01392 785 00200
   VCID: 78FF0E6B0B2690DEAC3-802D
   Subsystem 1 - Component:   Sounder No Answer
   Subsystem 2 - Part No: 1K0 907 719 B
   Component: Neigungssensor  004 0003
   Subsystem 3 - Part No: 1K0 951 177
   Component: Innenraumueberw.004 0101
1 Fault Found:
01134 - Alarm Horn (H12)
            004 - No Signal/Communication
The alarm horn doesn't sound when the alarm goes off nor when locking/unlocking the car (with chirps enabled), so I'm assuming that the horn needs replacing.
It's the 2 photo sensors that I'm stuck with....any advice would be appreciated :smiley:
Offline itavaltalainen
Re: Some fault code help...
« Reply #1 on: 07 July 2014, 22:51 »
Did it ever have the windscreen replaced?
Offline dom
  • Back in a Mk4
« Reply #2 on: 08 July 2014, 09:02 »
Not that I know of, why do you ask?
« Reply #3 on: 09 July 2014, 13:45 »
Photo sensor is glued on it... I it was replaced and old cam stripped of the old glass and glued back onto new then chances are it may have gotten damaged and may also not have been calibrated.
Offline dom
  • Back in a Mk4
« Reply #4 on: 09 July 2014, 16:43 »
I thought that the photo sensor was on the dash by the centre vents, or is there another near the rear view mirror?
Offline th3_f15t
« Reply #5 on: 10 July 2014, 11:53 »
I think it's on the windscreen behind the rear view mirror. It might be worth seeing if your intermittent wiper setting still works as if the windscreen has been replaced, the rain sensor function will also likely be faulty if this wasn't replaced. Least then you know the reason for the light sensor!
I assume you've tried setting off the alarm to see if it does work?
Moving over to Flickr, sorry for the broken picture links!
Offline dom
  • Back in a Mk4
« Reply #6 on: 10 July 2014, 12:39 »
Cheers, the windscreen is the original as it's stamped up in the bottom corner. I'll try the intermittent wiper setting in a minute.
I've locked the car with the drivers window open and waved my arms around inside to set the alarm off, the indicators flash but there is no siren. I've also enabled alarm chirp when locking/unlocking the car via vagcom and this doesn't work either.
Offline topher
  • Administrator
  • fully functioning
« Reply #7 on: 10 July 2014, 13:14 »
photosensors are by the dash vents the rain/light sensor is on the windscreen thats something different. The faults show intermittent did they not clear dom?
Offline dom
  • Back in a Mk4
« Reply #8 on: 10 July 2014, 15:17 »
Cheers, that's what I though. They aren't clearing at all, I've had Vagcom on it a few more times since to enable various things and to code in the cruise control. Each time I've cleared codes they've come back immediately, is it something you've come across before?
Offline th3_f15t
« Reply #9 on: 10 July 2014, 16:57 »
Every day's a learning day, cheers for that. Could the sensors in the dash need replacing?
