Author Topic: Traction control warning light??  (Read 6092 times)
Offline MBCGTI
« on: 06 July 2014, 19:28 »
So I've just come back from holiday after a week, the car has been sitting idle for the week so decided to start it up and get it to temp to make sure it is okay.
As I turned it on I touched the brake pedal and the light below came on
The front brake discs and pads are new, the rears are all good and the fluid is at the correct level.
I have tried to look on here, MK4 forum and golf GTi forum and cant seem to find what it means.
Any help??
Mike
Offline james2
  • No scammers please.
Re: Traction control warning light??
« Reply #1 on: 06 July 2014, 20:33 »
They go out after its running ? if so its fine
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline MBCGTI
« Reply #2 on: 06 July 2014, 21:08 »
Nope, stays on whilst running.
Offline golf turbo47
  • PURE BOOST!!!
« Reply #3 on: 06 July 2014, 21:31 »
Maybe replace Speed sensor, or could need a clean happen on mine before.
Silver 2001 1.8T AUM. Revo remap. hybrid K03s.  jetex filter. forge 007p. decat pipe. custom exhaust. anni front valence. rear 4mo valence. anthracite montreal 2 alloys. To be continued....... TIP, H&R suspension,Black 19" RS4 alloys, Carbon fibre wrap roof. anni rear valence, Almost there.....
Offline MBCGTI
« Reply #4 on: 06 July 2014, 21:34 »
Although I'm reasonably handy with a spanner is this a simple job to do as I don't want to break the bank at a garage but if its not too much then ill probably just get them to do it.
Offline jake-w07
« Reply #5 on: 06 July 2014, 21:38 »
Id get it scanned first could be a few things
Silver Golf GTi 25th Anniversary 1.8T - Milltek Non Res Catback - 3" Downpipe & Decat - Forge 007p - ITG Cone Filter - Custom Remap
Offline MBCGTI
« Reply #6 on: 06 July 2014, 21:41 »
Anyone know any reputable VW specialists around Northamptonshire??
Offline damien010685
« Reply #7 on: 07 July 2014, 01:13 »
Might be the brake sensor switch that's what happens with mine! As others have said scan it first as the traction light means many diff things
Offline james2
« Reply #8 on: 07 July 2014, 20:05 »
Have you taken it for a good drive and see if they go out ?
Offline MBCGTI
« Reply #9 on: 11 July 2014, 22:29 »
Ive taken it on a long run and it didn't go off, I turned the engine off and back on again and it went off but now its always on.
When I first start the car it doesn't come on until I brake for the first time.
