Author Topic: G60 / VR6 clutch conversion done today, but....  (Read 3118 times)
Offline MoMartin
« on: 01 July 2014, 17:38 »
Okay, so me and a friend did the g60 / vr6 conversion today, (He has a pit/ all the right tools) all went well, but as soon as i took it out for a drive i noticed that there's more engine noise than there used to be. Has anyone else experienced this / is it common?
Thats my only problem (if it is a problem), I'm loving how light the clutch is now though.
Cheers, Mo
Offline andy68
Re: G60 / VR6 clutch conversion done today, but....
« Reply #1 on: 01 July 2014, 18:54 »
some people report a little chatter on idle, put the ECS kit on mine with the lighter flywheel, got a bit more noise, but some of that is probably because of the uprated engine and dogbone mounts, has got quieter over time,
Offline MoMartin
« Reply #2 on: 01 July 2014, 20:05 »
Mine seems to make more noise when at about 3000 rpm, i don't really mind the sound, as it makes the car sound a bit more throaty, but i just wanted to ask around incase its something i've done wrong.
Cheers, Mo
Offline rockmonkey69
« Reply #3 on: 01 July 2014, 21:18 »
I run a 13lb flywheel as part of the spec stage 3 kit on my 20vt and there's no chatter, pleasantly surprised
Offline MoMartin
« Reply #4 on: 01 July 2014, 23:39 »
So what I'm experiencing is pretty normal then?
« Reply #5 on: 02 July 2014, 08:02 »
Seems so, luck of the draw it seems, my previous setup was the vr6/g60 and it was just like oem, only difference was a lighter clutch pedal.
Offline Dalo Harkin
« Reply #6 on: 02 July 2014, 12:24 »
I haven't noticed any additional noise with mine, saying that the turbo spools quite loud on mine anyway so I doubt I would
Offline MoMartin
« Reply #7 on: 03 July 2014, 00:04 »
Strange how it can be luck of the draw, i guess everything is slightly different though.
and you would definitely notice it dalo, well on my car it certainly made a difference.
« Reply #8 on: 03 July 2014, 08:11 »
Most my mates run stage 3 or stage 3+ clutch kits from spec and I run the stage 3, some of us get a lot of chatter and others get nothing, I'm starting to think it's down to whether you go for the aluminium or steel flywheel but I didn't think the g60 flywheel was aluminium. When you refer to more engine noise do you mean clutch chatter?
Offline Dalo Harkin
« Reply #9 on: 03 July 2014, 12:42 »
mine is definitely steel
