Author Topic: Its leaking from around the rim sir!  (Read 4465 times)
Offline Len
« on: 30 June 2014, 17:20 »
My Passat has had a soft tyre problem for months, yea bad thing I know!
It would go down to approx. 15psi but take about 2/3 weeks to do this.
last week Thursday I think it was down again so pumped it up.
Then yesterday I was out in the car and noticed it was almost flat again.
I had pulled into the local garage but somebody was using the air.
But in the same forecourt area is a Kwik-Fit so against my judgement I thought I had better get it checked out!
So I watched as the guy checked the tyre on the car (hoisted of the ground)
Then he took the wheel off and sprayed it with a solution all round the tread still nothing
Then he lays the wheel down and sprays around the rim, both sides.
Comes into me in reception and says its leaking from around the rim!
never heard of this before but hey he says he will take the tyre off and clean the surfaces and put it back on with a good bit od sealer which he did and I watched and yea seems to have done the trick!
Kind of amazed that's all
www.sas.org.uk
www.the-ace.org.uk
Offline barrym381
Re: Its leaking from around the rim sir!
« Reply #1 on: 30 June 2014, 18:47 »
kind of amazed you have never heard of this before its really quite common  :smiley:
Offline BobbyT
« Reply #2 on: 30 June 2014, 19:38 »
I get leaking from around the rim, I just courtesy wipe
« Last Edit: 30 June 2014, 20:15 by Rob Toogood »
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #3 on: 30 June 2014, 19:46 »
Normally its corrosion on the wheel under where the bead fits, cleaning does sort it, but if the surface is now porous, then expect the tyre to deflate again, it may take a bit longer though!
Not as much of late, but in the recent past, I've known of wheels having to be scrapped, as nothing seems to solve the problem permanently! But yes, a very common everyday problem
Hope yours is OK :cool:
Thom
Offline Bellend
« Reply #4 on: 30 June 2014, 21:58 »
Thom
Surely paint or a sealant on the surface would stop it?
Where all my moneys went.
Offline Thom89
« Reply #5 on: 30 June 2014, 22:22 »
[/quote]
[/quote]
Ford "Pepperpots" iirc, and a few others, I think the wheels made by GKN, and were as porous as a sponge!
They would corrode around the bead seating area. Out of everything we tried, blasting and powdercoat seemed to work best... for a few months! until the bead of the tyre wore its way through the powdercoat, and it was back to square one! wheels these days seem to be far better quality, and rarely do you now see flaking lacquer like you used to 10 years ago
Probably they had to up the game because of warranty claims!
Thom
Offline Len
« Reply #6 on: 01 July 2014, 13:57 »
 :grin:
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #7 on: 01 July 2014, 13:59 »
Thanks Thom
No I have never heard of this before!
have heard about split rims leaking but that is between the parts of the wheel and why I shied away from buying some!
www.sas.org.uk
www.the-ace.org.uk
Offline Sam
  • Sam I am
« Reply #8 on: 02 July 2014, 14:57 »
I think this has happened on pretty much every car I have owned.  :huh:
VW BUSH
« Reply #9 on: 02 July 2014, 15:09 »
Just goes to show you are never too old to learn something new :grin:
