Author Topic: Its leaking from around the rim sir!  (Read 4475 times)
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: Its leaking from around the rim sir!
« Reply #10 on: 02 July 2014, 17:18 »
it's pretty common. When i worked at kwik fit it was a daily occurance. Some steel rims we would go round them with a blow torch and wire brush then use bead sealer. Seen some corroded right through. Alloys to suffer with road salt getting in under the paint, all four wheels on my corrado are deflating as i type due to it. Sometimes a rim leak wont show itself when the wheels off as some will only leak when loaded on a certain area.
Offline Ant1981
  • Feed me, prod me
« Reply #11 on: 07 July 2014, 13:46 »
Bead sealant sorts this problem out, unfortunately not all garages are using it. Most of the mainstream garages I've used, suchs as ATS do a horrific job of tyre fitting and don't use bead sealant, so my tyres go flat quickly. I've since found a local small garage who use bead sealant. Although they're not the cheapest to buy tyres from, they fit them properly and you'll not need to go back to get a leak sorted.
'09 Kawasaki Ninja ZX-6R
Offline Len
« Reply #12 on: 11 July 2014, 20:59 »
Just goes to show you are never too old to learn something new :grin:
Very true!
Just never happened to me before so never heard of it!
www.sas.org.uk
www.the-ace.org.uk
Offline Jasikasisback
« Reply #13 on: 06 August 2014, 10:36 »
Check the valve as that might be leaking...happened on my tyre...
For the money they take when changing a tyre they should put a new valve in and coat the rim...some just don't do it as they are quite cheap....but a good tyre place will do that.
Good luck...as a new valve will be a lot more cheaper than a new rim...
Offline Len
« Reply #14 on: 11 September 2014, 13:21 »
have changed wheels and tyres now!
Got my old RS8 reps back via Billy! :laugh: :laugh: :laugh:
www.sas.org.uk
www.the-ace.org.uk
