Author Topic: just bought a EPMAN RACING PARTS DUMP VALVE  (Read 4941 times)
Offline gavsgti
« on: 26 June 2014, 22:21 »
as tittle says i just bought a epman racing parts dump valve and its brand new in box but doesnt come with no instructions as to what spring i should put in it ?
ive read posts about certain springs for standard/mapped etc on the forge 007/008 and was wondering if it would be the same with this one
ive notlong since bought the car and was told it has been mapped but im not sure what to or what map they did or if its actually been mapped (defo feels like it has )
so does anyone know these dumpvalve and know what spring i should fit it with ?
im new to modding the turbos so any advice would help a lot
thanks in advance
gav
Offline rio_gti
Re: just bought a EPMAN RACING PARTS DUMP VALVE
« Reply #1 on: 26 June 2014, 23:21 »
Could always try the ones you have, if you get turbo chatter use a weaker one and if you loose boost use a stronger one
Offline dom
  • Back in a Mk4
« Reply #2 on: 27 June 2014, 17:44 »
My advice, ditch the dump valve in favour of a recirculating one like you're supposed to have.
Offline gavsgti
« Reply #3 on: 27 June 2014, 20:59 »
thanks for reply ill give it a go with the springs
and it is a recirculating valve
this is like the one i got :-
http://www.ebay.co.uk/itm/281362749509?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Offline Kruga
  • Silver - MK4 1.8T AGU 2000
« Reply #4 on: 28 June 2014, 00:02 »
Bin it and spend the money on a proper dump valve >  Forge 007p
Offline harlemex
« Reply #5 on: 28 June 2014, 16:14 »
forge is overpriced and no better than the ebay cheapies.
Offline Kruga
« Reply #6 on: 29 June 2014, 11:50 »
if you say so...
Offline gavsgti
« Reply #7 on: 29 June 2014, 18:31 »
well after fitting the valve i went to change spring and noticed that one of the rubber seals had snapped so wasnt best happy with the epman one so put the standard one back on
also the turbo sounds weird and i dont think its boosting like it did before and also seems to be a weird sound
i had to change the pipe what gos off the top of the valve due to it splitting when i tried putting it on the the valve could it be this pipe whats making that happen? the pipe i used was a braided pipe but it didnt seem as tough rubber as the standard one
also whats this pipe called as im wanting to replace it with a silicone one ?
any advice will help me lots
thanks in advance
Offline Dalo Harkin
« Reply #8 on: 30 June 2014, 08:32 »
if it was making a weird noise, was it like a chirp? if it is the DV is the wrong way round.
I personally have only used Forge on mine, but as the others have said they are overpriced 'scene tax' have a look in the classifieds as there are always some in there.
Offline gavsgti
« Reply #9 on: 30 June 2014, 20:37 »
thanks for the reply
i put the old DV back on and same way as it was before and its still making the same noise i was thinking as i have changed the pipe that goes on the top nipple of the DV it could of been that what was making it do it maybe the rubber inside is to weak or ive put a to longer pipe on?
im not sure if that pipe is a breather vacum or what it is
im wanting to renew that pipe for a silicone one to see if that makes a difference but im not sure what the pipes called so not sure what to look for
at the moment im trying to do what i can at a tight budget since i recently lost my farther and had to take a month out of work to sort his house etc as it was unexpected so till i can catch up on the jobs and get the money in was just trying to so things i wanted to as a sorta temp thing i am going to gt the forge eventually but working self employed and the time off ive had to have just couldnt afford one then
so now im just gunna trty get the car sounding as it should till i can afford everything else
hoping to do the car up over time for shows etc as its my little project tho its the first golf turbo/mk4 ive owned i always had the mk2s before this so any advice people can give me would be appreciated
thanks in advance
