Author Topic: Cr@p reception from radio in a Mk3  (Read 2090 times)
Offline Bazzer
« on: 08 September 2005, 10:12 »
Hi all
I've got a Kenwood headunit that's worked ok in all the cars I've had recently, put it in my mk3 the reception for 'national' stations is pants! Looked behind the dash and all the connections are good. Any ideas?
Ta
« Last Edit: 08 September 2005, 10:14 by Bazzer »
Bazzer
Offline GTI EDITION (aka LTD)
Re: Cr@p reception from radio in a Mk3
« Reply #1 on: 08 September 2005, 10:28 »
Does your mk3 have a bee sting ariel , if so it should have a booster that plugs inbetween the the radio and the ariel lead with a small wire coming from it that plugs into the electric ariel energising connection either on the radio or the multi plug that goes onto the loom .
If the booster is missing or faulty you will have probs with reception
Also on mk3s there is a joiner which is normaly situated either behind the N/S lower parcel shelf or behind the front section of the inner sill trim below the 'A' piilar but I can't remember if cars with Bee Sting roof ariels have this connection . But it's worth a look :smiley:
« Last Edit: 08 September 2005, 10:47 by Tarquin Fin-tin-lim-bin-lin-bim- bin-bim-bin bus-stop F'ttang F'ttang Olé Biscuit barrell ! »
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
Offline Mr Blue
« Reply #2 on: 08 September 2005, 10:39 »
i just earthed the middle wire on the ariel to the car. Works well :rolleyes:
Offline Bazzer
« Reply #3 on: 08 September 2005, 11:34 »
I'm not sure about the amplifier - I couldn't see anything that looks like it plugs into a standard ISO radio connector... There is a 2 pin connector dangling behind the glove box with nowhere to plug in, but it looks like a VW plug, not an ISO (or bullet) plug. Without knowing what this is I'm reluctant to shove 12v up it! Know where the amp is supposed to be? It's not by the glove box, deffo...
As for earthing the middle wire - on my mk2 I insulated the shield from the connector (so the pin was the only thing making connection) and that worked ok but I'm sure things should work without resorting to bodging it!!
And BTW I do have a beesting....
Bazzer
Offline Overseer
« Reply #4 on: 08 September 2005, 16:45 »
the reception on my valver is arse too... so i'd like to know how this goes :)
luckily i listen to CDs a lot though...
