Author Topic: Aum and Agu  (Read 1986 times)
Offline reedy20vturbo
Aum and Agu
« on: 16 June 2014, 21:54 »
Hello,
Why doesn't the aum backfire like the agu? No matter what I do my aum won't pop and bang but my mates agu will bang like fook and spit flames, just wondering.why that is?
Offline rockmonkey69
Re: Aum and Agu
« Reply #1 on: 16 June 2014, 22:18 »
Mine is an AUM and it pops and produces very large flames, it does it when I come off the throttle after I was on boost and constantly on launch control. Yours might need more mods  :evil:
Re: Aum and Agu
« Reply #2 on: 16 June 2014, 22:28 »
That sounds awesome mate! I do have a few mods, nothing serious,  forge recirculation valve, s2000 filter, decat pipe, what mods do you have mate? :)
Re: Aum and Agu
« Reply #3 on: 16 June 2014, 22:42 »
Integrated engineering conrods
Integrated engineering Pcv adaptor
Port matched inlet and head
Supertech stem seals
Newsouth power gasket
Ported & polished turbo manifold
K300 turbo
1 bar actuator
80mm sfs intake pipe
3" maf
Eurojet race intercooler
3" downpipe
3" decat
3" boost factory catback
3.25" backbox
Billet injector seats
Genesis 550cc injectors
Sytec fuel pump
Aem water methanol injection
Forge SAI delete blank
Forge 007p diverter valve
Forge throttle body hose
CTS Turbo throttle body spacer
N112 delete
N249 delete
SAI delete
4" inlet velocity stack air filter
Vf engineering upper engine mounts
Powerflex lower engine mount bush
Superpro lower engine mount bush
Power steering delete
Air con delete
BKR7E 0.028"
Quaife LSD
Spec stage 3 6 puck clutch and pressure plate
13lb steel flywheel
Forge motorsport baffled sump
Stahlbus drain valve
Pretty sure there's more engine mods but I ain't in front of my computer so I can't check my list.
It did pop and flame on stage 2 map when I had the k03s but not as much as it does now it's had the little turbo upgrade and mapped with launch control and no lift shift.
« Last Edit: 16 June 2014, 22:47 by rockmonkey69 »
Re: Aum and Agu
« Reply #4 on: 16 June 2014, 22:48 »
Fook me! That must go like sh!t off a stick mate! Did you do those mods? What bhp? I've had mine for a year now, I'm 19 and spend more time cleaning it than I do driving it,  what do you think I should do next mod wise?
Re: Aum and Agu
« Reply #5 on: 16 June 2014, 22:57 »
I wasn't aiming for power, the car is more for track use so handling took priority, can't recall exact figure, but it is over 300bhp and also over 300bhp per ton. It's not a great deal of power but it's enough to be competitive on slower circuits and fine for street use.
Next mod for you is difficult to say without knowing what sort of power you're aiming for. Most people wanting a bit more would go for a good flowing exhaust, decat, larger intake pipe, uprated actuator, good flowing front mount intercooler, s3/TT injectors, uprated fuel pump, water methanol injection and a stage 2 remap.
It goes without saying if you looking for 400+ then the above list is quite useless. I'm guessing this is your first attempt at modifying a car, its a good idea to familiarise yourself with the amount different turbos are capable of flowing.
« Last Edit: 16 June 2014, 23:05 by rockmonkey69 »
Re: Aum and Agu
« Reply #6 on: 16 June 2014, 23:02 »
Mental! I'm looking for about 250BHP, need to replace my cam chain tensioner first, it's tappy on start up then it goes quiet after a few minutes, but there expensive so I need to save some money and sort that then start modding, thanks for the info mate
