Author Topic: Cruise Control Exclamation!  (Read 12198 times)
Jimmymature
« on: 16 June 2014, 10:22 »
Hi gents, I've got an exclamation mark against the cruise logo on the dash. Cruise works sometimes normally after I've just set off then the exclamation appears and cruise won't engage!
Had anyone got any tips other than get the dealer to charge me £80 just to look at it?
Cheers,
Jim
Offline Rgdogg
Re: Cruise Control Exclamation!
« Reply #1 on: 16 June 2014, 13:32 »
Just sent you a pm jimmy.
Gti, Candy White, 3door, DSG, Leather, Rear LEDs, Bluefin, Milltek, vwr intake, Focal speakers.
Jimmymature
« Reply #2 on: 16 June 2014, 14:06 »
Thanks mate I'll give them a call.
Jim
Offline joe6
« Reply #3 on: 20 June 2014, 16:35 »
Just started to get the same. Any advice much appreciated.
Offline Ess_Three
« Reply #4 on: 20 June 2014, 17:09 »
The exclamation mark seems to mean you have a standing fault with an ECU - likely the engine ECU,
I had it recently when my throttle pedal was playing up: EPC light on, 'Engine Fault - Workshop' up on the DIS, Exclamation mark by the cruise indication and no boost available - limp mode.
It would come in/out...and with every exclamation mark came limp mode.
If you get your faults scanned you should be able to work out what's causing it.
..but gaining motorcycles.
Offline dubber36
« Reply #5 on: 20 June 2014, 18:14 »
It makes VCDS at £240 look like a worthwhile purchase. 3 lots of VW diagnostics at £80 and it's paid for.
It might just have been a bogus fault caused by irregular voltage in the first place and needs the stored codes erasing to fix it.
Offline joe6
« Reply #6 on: 21 June 2014, 22:37 »
Thanks for the advice. Will get a VCDS scan as a starting point and take it from there. Know someone with Ross tech software. Hopefully just a bogus alert as there are no other fault lights or messages.
Jimmymature
« Reply #7 on: 22 June 2014, 15:19 »
Thanks gents, I've noticed what triggers it to come on! When I use the indicator turning right that's when the exclamation comes up and the Cruise stops working!
Very odd, anyone heard of this? I know i'll end up having to pay £80 for the dealer to scan the error codes as I don't know anyone local with VCDS.
Thanks gents,
Jim
Offline dubber36
« Reply #8 on: 22 June 2014, 19:24 »
Where is local Jim?
Jimmymature
« Reply #9 on: 22 June 2014, 21:25 »
Where is local Jim?
Sunny Berkshire mate  :cool:
