Author Topic: vr engine.  (Read 1966 times)
Offline sharki786
  • GOT BOOST??
vr engine.
« on: 15 June 2014, 13:48 »
Fitted a vr to a mk3 golf. Got ecu, clocks, key chip, loom etc. Anyway its all in but car starts then cuts out. Put genuine vag com onto it and came up with different key used. Now my mate says that i need the maching transponder box to get the car started. Can anyone confirm that.
i also rang a bloke who does this and he is saying that he want 100 to pair it. I feel like the guy is bending me over backwards and trying to f*ck my ars3hole
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline itavaltalainen
Re: vr engine.
« Reply #1 on: 15 June 2014, 19:38 »
If you have VCDS then just remarry...
but why do you create 5 threads (feels like 5) for what's really the same topic  :whistle:
Offline sharki786
  • GOT BOOST??
Re: vr engine.
« Reply #2 on: 15 June 2014, 21:24 »
They started on different topics and all led to this lols
*****MK4 GTI T*****
Offline gasketface
Re: vr engine.
« Reply #3 on: 15 June 2014, 21:48 »
My mate shorted and cooked his 8v ecu a while back ( ithink i posted about it then ).
I got him an ecu,reader,transponder and chip off ebay for £50 and he fitted the chip and ecu as soon as it arrived.
Car started straight away and then died.Turned out he needed the transponder as well.
Once he fitted that the car ran fine,no idea why this is but i guess you need the transponder as well.
Offline sharki786
  • GOT BOOST??
Re: vr engine.
« Reply #4 on: 16 June 2014, 10:13 »
Ok there seems to be some confusion with what a transponder is. Some say the transponder is the small chip in the key others say its the black box behind the clocks that translates the code read from the chip to the ecu.
*****MK4 GTI T*****
Offline tweed
Re: vr engine.
« Reply #5 on: 16 June 2014, 10:28 »
Yep you need both.
Re: vr engine.
« Reply #6 on: 17 June 2014, 07:15 »
A transponder is something that transmits a signal... the box in dash the the immobiliser control unit.
You need both for the system to work but the mk3 immobiliser is so simple all you need is the login pin - then you can marry any compatible transponder chip to it.
