Author Topic: Car broke down, fault code retrieved.  (Read 1734 times)
Offline vwgolfv5
« on: 15 June 2014, 12:35 »
My V5 broke down on Friday. I have a VAG reader and a code 16706 was store something to do with the engine speed sensor ?
The symptoms were.
The first thing that happened was the EPC light came on and my revs altered.
Shortly afterwards the Check Engine light came on.
Then the car just cut out and refused to start (caused mayhem at the traffic lights)
After about 5 minutes the car restarted and I managed to limp home.
The revs were shooting up and down, from 800rpm upto about 1800rpm, it did this constantly.
On my way home I got another error on my dash, the engine pressure warning, even though my engine oil is at the perfect level and no leaks were showing, so I put that down to what ever else was going on.
I've been out to the car now and she started first time and sounds perfectly normal.
Ideas please ?
Offline barrym381
Offline vwgolfv5
Re: Car broke down, fault code retrieved.
« Reply #2 on: 15 June 2014, 12:47 »
http://wiki.ross-tech.com/wiki/index.php/16706/P0322/000802
Thanks, so that confirms it.
Is the sensor located under the car near the oil filter ?
Offline Dalo Harkin
« Reply #3 on: 16 June 2014, 08:33 »
Yep that's the one, mine went recently
